[Geoserver-devel] Upcomming Geoserver Release
I hope to have a release out at the end of next week or the beginning of
the week after.
I havent done a lot of testing of the SVN versio - thats what I'm hoping
to do next week (as well as fix a few reported bugs).
Major Changes
1. Geoserver now passes all WFS and WMS CITE tests!
2. Geoserver WMS now does reprojection!
3. Geoserver now allows you to define your geoserver data directory
(previously called "GEOSERVER_HOME")
4. Added a bunch of "helpers" for SRS (spatial referencing system) since
people will have to define their SRSs now
5. Chris added some .sld schema validation - I havent looked at it yet.
Minor Changes
1. bug fixes
2. lite renderer improvements
3. added a WFS lock tutorial
(http://docs.codehaus.org/display/GEOS/Feature+Locking)
4. upgraded to latest geotools
You can define your geoserver data directory in three ways:
1."GEOSERVER_DATA_DIR" system property.
   this will most likely have come from "java -DGEOSERVER_DATA_DIR=..."
or from you web container's GUI
2. "GEOSERVER_DATA_DIR" in the web.xml document:
     <context-param>
            <param-name>GEOSERVER_DATA_DIR</param-name>
            <param-value>c:\myGeoserverData</param-value>
     </context-param>
3. Defaults to the old behavior - ie. the application root - usually
"server/geoserver" in your .WAR.
To make a new one of these data directories, just:
1. create the data directory
2. copy "data/" from an already running geoserver
3. create a "WEB-INF/" directory
5. copy "catalog.xml" and "services.xml" into the WEB-INF/ directory
Dave
This mail sent through IMP: https://webmail.limegroup.com/
