[Geoserver-devel] update reported succesfull, but no changes made in database
When updating a feature with this request:
<?xml version='1.0'?>
<wfs:Transaction
version='1.0.0'
service='WFS'
xmlns='http://localhost:8080/geoserver/
xmlns:wfs='http://www.opengis.net/wfs
xmlns:ogc='http://www.opengis.net/ogc
xmlns:gml='http://www.opengis.net/gml
xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance
xsi:schemaLocation='http://www.opengis.net/wfs
../wfs/1.0.0/WFS-transaction.xsd'>
<wfs:Update typeName='test_boundary'>
<wfs:Property>
  <wfs:Name>SOURCE</wfs:Name>
  <wfs:Value>TT</wfs:Value>
</wfs:Property>
<ogc:Filter>
  <ogc:FeatureID fid='TEST_BOUNDARY.1590'/>
</ogc:Filter>
</wfs:Update>
</wfs:Transaction>
the Transaction is reported to be succesfull, but when I check it in my
Oracle database, no changes have been made. In the logfile I found that
there is "... - Transaction connection not open or set to manual commit",
see below. Should Oracle been set to autocommit (which is not preferable,
since there are users that need the manual commit) or can I somehow tell
Geoserver to set it to autocommit only for its "Transaction session"? And if
so, how? I've read something on setAutoCommit and Postgresql, but can't
figure out how to actually use that, especially for Oracle. Or could there
be an entirely other problem, e.g. with JDBC?
For those interested in the logfile, please see below for the possibly
relevant parts of it. For those not interested, sorry for filling up your
mailboxes... Nevertheless, I hope to read some suggestion(s). Thanks!
Thijs Brentjens
begin logfile
11516391 [FINER] org.vfny.geoserver.responses.TransactionResponse - doing
transaction response
11516391 [FINER] org.vfny.geoserver.responses.TransactionResponse - got
lockId: null
11516391 [FINER] org.vfny.geoserver.config.TypeRepository - checking
isLocked on: test_boundary, null, null
11516391 [FINER] org.vfny.geoserver.config.TypeInfo - params is
{table=TEST_BOUNDARY, user=user, instance=gisbase, passwd=****, host=host,
port=1521, dbtype=oracle}
11516391 [FINER] org.geotools.data.DataSourceFinder - Available Data
Sources:
11516407 [FINER] org.geotools.data.DataSourceFinder - PostGIS spatial
database
11516407 [FINER] org.geotools.data.DataSourceFinder - ESRI(tm) Shapefiles
(*.shp)
11516407 [FINER] org.geotools.data.DataSourceFinder - Oracle Spatial
Database
11516407 [FINE] org.geotools.data.jdbc.ConnectionPool - Getting available
connection.
11516625 [FINE] org.geotools.data.oracle.OracleDataSource - Column Name =
FID; Column Type = NUMBER
SHAPE; Column Type = SDO_GEOMETRY
Getting geometryAttribute
11516625 [FINER] org.geotools.data.oracle.OracleDataSource - Checking
geometry using: SELECT SHAPE FROM TEST_BOUNDARY WHERE ROWNUM = 1
geom class class com.vividsolutions.jts.geom.MultiLineString
best geom class class com.vividsolutions.jts.geom.MultiLineString
11516657 [FINE] org.geotools.data.oracle.OracleDataSource - Column Name =
OBJECT_ID; Column Type = NUMBER
11516688 [FINE] org.geotools.data.oracle.OracleDataSource - Column Name =
SOURCE; Column Type = VARCHAR2
11516719 [FINE]
org.geotools.data.jdbc.ConnectionPool$ConnectionListManager - Connection
closed - adding to available connections.
11516719 [FINER] org.vfny.geoserver.config.TypeInfo - data source is null
11516719 [FINE] org.geotools.data.jdbc.ConnectionPool - Getting available
connection.
11516719 [FINER] org.geotools.data.oracle.SqlStatementEncoder - Creating
sql for Query: mf=100000000 filter=null useMax=true
11516719 [FINER] org.geotools.data.oracle.SqlStatementEncoder - sqlString =
SELECT FID FROM TEST_BOUNDARY WHERE ROWNUM <= 100000000
11516735 [FINE] org.geotools.data.oracle.OracleDataSource - Adding feature:
TEST_BOUNDARY.1590
TEST_BOUNDARY.1591
11517500 [FINE] org.geotools.data.oracle.OracleDataSource - Adding feature:
TEST_BOUNDARY.1738
TEST_BOUNDARY.1739
11518579 [FINE]
11518579 [FINER] org.vfny.geoserver.responses.TransactionResponse - sub
request is TypeName: test_boundary
handle: null
ReleaseAll: true
filter: null
Property - Name: SOURCE, Value: TT
11518594 [FINER] org.geotools.data.DataSourceFinder - Available Data
Sources:
11518594 [FINER] org.geotools.data.DataSourceFinder - PostGIS spatial
database
11518594 [FINER] org.geotools.data.DataSourceFinder - ESRI(tm) Shapefiles
(*.shp)
11518594 [FINER] org.geotools.data.DataSourceFinder - Oracle Spatial
Database
11518594 [FINE] org.geotools.data.jdbc.ConnectionPool - Getting available
connection.
11518782 [FINE] org.geotools.data.oracle.OracleDataSource - Column Name =
11518797 [FINE] org.geotools.data.oracle.OracleDataSource - Column Name =
11518797 [FINER] org.geotools.data.oracle.OracleDataSource - Checking
11518813 [FINE] org.geotools.data.oracle.OracleDataSource - Column Name =
11518829 [FINE] org.geotools.data.oracle.OracleDataSource - Column Name =
11518844 [FINE]
11518844 [FINER] org.vfny.geoserver.config.TypeInfo - data source is
org.geotools.data.oracle.OracleDataSource@anonymised.com
11518860 [FINER] org.vfny.geoserver.responses.TransactionResponse - metad
is supportsAdd: true
supportsRemove: true
supportsModify: true
supportsSetFeatures: true
supportsRollbacks: true
supportsAbort: false
supportsGetBbox: true
hasFastBbox: true
11518860 [FINE] org.geotools.data.jdbc.ConnectionPool - Getting available
connection.
11518860 [FINE] org.geotools.data.oracle.OracleDataSource - Transaction
11518860 [FINE] org.vfny.geoserver.responses.TransactionResponse - attribut
type is DefaultAttributeType [name=SOURCE , type=class java.lang.String ,
nillable=true], values is TT
committing Lock Id: null
release all: true
handle: null
handle: null
ReleaseAll: true
filter: null
11518860 [FINE] org.geotools.data.oracle.OracleDataSource - Closing
Transaction Connection
11518875 [FINE]
11518875 [FINER] org.vfny.geoserver.responses.WfsTransResponse - returning
xml <?xml version="1.0" encoding="UTF-8"?>
<wfs:WFS_TransactionResponse
   version="1.0.0"
   xmlns:wfs="http://www.opengis.net/wfs&quot;
   xmlns:ogc="http://www.opengis.net/ogc&quot;
   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
   xsi:schemaLocation="http://www.opengis.net/wfs
http://localhost:8080/geoserver/data/capabilities/wfs/1.0.0/WFS-transaction.
xsd">
   <wfs:TransactionResult>
      <wfs:Status>
         <wfs:SUCCESS/>
      </wfs:Status>
   </wfs:TransactionResult>
</wfs:WFS_TransactionResponse>
end logfile
