The OracleSpatial datastore has been updated to use the SDO class rather than require the oracle sdoapi.zip.
This change is isolated in the SDOAttributeIO class - all references to AdapterSDOand Adapter JTS have been commented out.
I am hoping that anyone with Orale spatial access can give this one a whirl tomorrow so Chris can make his release. The release process is the same - place the real oracle jdbc driver in the libs directory of geoserver (you no longer need sdoapi.zip) and everything should work out.
Jody
