Hi Brian,
I second Jody. Mind, it still has to work with the default version of Jetty we build the windows/osx/bin packages with,
and common Tomcat versions, it’s up to you to check that’s the case.
Also mind, only the developer series (master) uses a recent Jetty version (9.2, landed a few
days ago) whilst the stable and maintenance are still depending on Jetty 6, which is several
years old (so, it might not support servlet 3.1)
On Wed, Oct 28, 2015 at 9:00 PM, brian.blain <brian.blain@anonymised.com> wrote:
I am deploying GeoServer 2.7.2 onto WebLogic 12.1.3. I did not have a problem
configuring the DATA_DIR to work using an Environment Variable but what I
would prefer to do is deploy using a WebLogic plan xml. The plan file would
allow me to override the without exploding or modifying the
war. This helps when deploying to multiple environments that I do not need
to modify the OS variables. Unfortunately, WebLogic does not support this
feature for xml files that use DTD.
Given that DTD is older and the web.xml is using web-app 2.3 is there a
specific reason it has not been updated to use the servlet 3.1
specification?
I updated the web.xml on my own with this and have not seen any issues.
Brian
View this message in context: http://osgeo-org.1560.x6.nabble.com/Update-web-xml-from-DTD-to-XML-Schema-tp5233189.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
