All the old issues are still open in the new Jira and without component. Is there a plan to continue with scripted updates? Is there anything I could help with?
-Jukka Rahkonen-
-Jukka Rahkonen-
On Tue, May 5, 2015 at 7:27 PM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
could help with?
I inquired Harrison privately a week ago, and then again two days ago, here
is his last answer (of two days ago):
Hey Andrea,
Sorry I missed your first e-mail. Status and category will be going in
tonight, with the rest getting finished off early next week. Sorry this has
ended up turning into a month long thing... the different JIRA versions
ended up being a much larger issue than I anticipated. I greatly appreciate
you and the rest of the GeoServer, GeoAPI, uDig, and GeoTools teams'
patience, and we will have this wrapped up shortly.
Let's see how short "shortly" really is?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I caught astrodog on IRC this weekend, and we have the following compromise:
jgarnett: one thing that is tricky is that we are holding off updating any tickets
jgarnett: since we are not sure if yoru work will overwrite their closed, resolution, fixed version etc…
astrodog: jgarnett: I can check to see if a ticket has been closed, and if so, ignore it.
astrodog: So you guys can close them out without causing a problem.
astrodog: Actually… why don’t we just go with “If it’s not set to ‘Open’, the migrator will not change the status.”
astrodog: That way, if you have something that supercedes whats in Codehaus, you can just work normally. If the status isn’t “Open”, then the migrator can just skip over that ticket for statuses.
So let us start closing / resolving issues as they are fixed, so our release notes are correct.
On 5 May 2015 at 10:33, Andrea Aime <andrea.aime@anonymised.com> wrote:
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-devel mailing list
Jody Garnett
On Tue, May 5, 2015 at 7:27 PM, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
I inquired Harrison privately a week ago, and then again two days ago, here is his last answer (of two days ago):
Hey Andrea,
Sorry I missed your first e-mail. Status and category will be going in tonight, with the rest getting finished off early next week. Sorry this has ended up turning into a month long thing… the different JIRA versions ended up being a much larger issue than I anticipated. I greatly appreciate you and the rest of the GeoServer, GeoAPI, uDig, and GeoTools teams’ patience, and we will have this wrapped up shortly.
Let’s see how short “shortly” really is?
Ing. Andrea Aime
@geowolf
Technical Lead
