[Geoserver-devel] Upgrade from Wicket 7.1.0 to 7.2.0
Wicket 7.2.0 was released 20 Jan 2016. In the interests of staying up-to-date, we should consider upgrading.
In addition, this Wicket release includes various bugfixes, included one which partially fixes https://osgeo-org.atlassian.net/browse/GEOS-7925
We are rather close to the release candidate, but I think it is probably best to upgrade sooner rather than later.
Torben
I would rather upgrade now during beta, and use RC to test. We can discuss in tomorrows meeting.
On 6 March 2017 at 16:23, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Announcing the Oxford Dictionaries API! The API offers world-renowned
dictionary content that is easy and intuitive to access. Sign up for an
account today to start using our lexical data to power your apps and
projects. Get started today and enter our developer competition.
http://sdm.link/oxford
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Jody Garnett
On Tue, Mar 7, 2017 at 1:23 AM, Torben Barsballe <
no objection, just a question. I see 7.6.0 is out, I read somewhere that
the 7.x series versions
are supposed to be a drop-in replacement. Did you look into this option at
all?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
no objection, just a question. I see 7.6.0 is out, I read somewhere that the 7.x series versions
are supposed to be a drop-in replacement. Did you look into this option at all?
Hadn’t looked at that, just followed the WICKET-6002 bug report to the first version it was fixed in.If 7.6.0 does indeed work as a drop-in replacement, then upgrading to that seems most sensible.
I will update my PR and run tests…
Torben
On Tue, Mar 7, 2017 at 12:31 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Mar 7, 2017 at 1:23 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Tried out 7.6.0, and it turns out we do have a regression, affecting JAIPage, CoverageAccessPage, and GlobalSettingsPage:
Expected close tag for ‘’ Possible attempt to embed component(s) ‘<wicket:message key=“submit”>’ in the body of this component which discards its body
MarkupStream: [markup = file:/Users/tbarsballe/repos/GeoServer/geoserver/src/web/core/target/classes/org/geoserver/web/admin/GlobalSettingsPage.html
<wicket:message key=“submit”>submit</wicket:message>, index = 1, current = ‘<wicket:message key=“submit”>’ (line 0, column 0)]
at org.apache.wicket.markup.MarkupStream.throwMarkupException(MarkupStream.java:526)
at org.apache.wicket.Component.replaceComponentTagBody(Component.java:4142)
at org.apache.wicket.markup.html.form.Button.onComponentTagBody(Button.java:222)
at org.apache.wicket.markup.html.panel.DefaultMarkupSourcingStrategy.onComponentTagBody(DefaultMarkupSourcingStrategy.java:70)
at org.apache.wicket.Component.internalRenderComponent(Component.java:2601)
at org.apache.wicket.MarkupContainer.onRender(MarkupContainer.java:1668)
at org.apache.wicket.Component.internalRender(Component.java:2401)
at org.apache.wicket.Component.render(Component.java:2329)
at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1526)
at org.apache.wicket.MarkupContainer.renderAll(MarkupContainer.java:1729)
at org.apache.wicket.MarkupContainer.renderComponentTagBody(MarkupContainer.java:1704)
at org.apache.wicket.MarkupContainer.onComponentTagBody(MarkupContainer.java:1659)
at org.apache.wicket.markup.html.form.Form.onComponentTagBody(Form.java:1707)
at org.apache.wicket.Page.onRender(Page.java:879)
at org.apache.wicket.markup.html.WebPage.onRender(WebPage.java:141)
at org.apache.wicket.Page.renderPage(Page.java:1018)
This regression was introduced in Wicket 7.5.0.
I can get tests to pass again by changing all instances of “Button submit = new Button(“submit”, new StringResourceModel(“submit”, this, null)) {” to “Button submit = new Button(“submit”) {”
This seems to match what the current implementation of most pages. Looking at the javadocs for StringResourceModel, it seems to be partially responsible for localization. I’ve tested in a different locale (French), and everything does appear to be working fine.
We are using StringResourceModel in quite a few other places, and while none of them seem to cause problems, it plausible that there are issues that are not caught by our test cases.
As an alternative, we can just upgrade to Wicket 7.4.0 for now.
Torben
On Tue, Mar 7, 2017 at 10:08 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Torben; I would like to try upgrading to 7.6.0 now (leaving the RC1 to test with). We can do a special request to test localization in the RC1 anouncement. I also note [i18n] Korean properties files synched from Transifex merged by Frank so we have a second reason to ask for localization testing.
On 7 March 2017 at 14:17, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Jody Garnett
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
