[Geoserver-devel] upgrade geofence hibernate
Hello,
I'd like to upgrade hibernate in geofence from 3.6.0.Final +spatial 1.1.1 to hibernate 5.x. Hibernate spatial pulls in old dependencies that conflict with recent postgres/postgis stores. Is there any objection to that?
Note - the same versions are defined in geoserver master pom, but they are only used by the geofence extensions. Monitor uses an even older version specifically defined in their own pom - ideally should be updated as well.
Kind Regards,
Niels
What dependencies are conflicting with recent postgres/postgis stores and what are actually the issues ?
Anyway Hibernate 3.6.0.Final was release 7 years ago and has two major versions on top of it so upgrading to a more recent version is probably something that should be done:
https://mvnrepository.com/artifact/org.hibernate/hibernate-core
My main concern is the impact on existing installations of GeoFence, taking in account the commonly used databases (PostgreSQL, Oracle, ...) which versions will still compatible ?
Hibernate rely on the JDBC driver of the database so the question can be rephrased, which JDBC versions are supported by 3.6.0.Final that are no supported by 5.x ?
The spatial extension of Hibernate also suffered several changes, do you see possible incompatibility issues ?
Nuno Oliveira
On 01-06-2017 15:00, Niels Charlier wrote:
Hello,
Kind Regards,
Niels
Check out the vibrant tech community on one of the world's most
Geoserver-devel mailing list
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
mob: +39 333 8128928
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
  The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
I don’t actually know… This is the only information that has been given to me. I could find out though, but I understand you agree with an upgrade in principle. From the hibernate website: "Hibernate 5.2 and later versions require at least Java 1.8 and JDBC 4.2. I think we could opt for hibernate 5.1 if that makes things more backwards compatible, because I was asked 5.x I cannot find documentation that lists migration issues. I am assuming I will face quite a few issues, but that these can be resolved. I am hoping that the test coverage is sufficient, so that if I can make all the tests work again I can assume that it works… Regards Niels
Hello Nuno,
On 01-06-17 17:00, Nuno Oliveira wrote:
My main concern is the impact on existing installations of GeoFence, taking in account the commonly used databases (PostgreSQL, Oracle, …) which versions will still compatible ?
Hibernate 5.1 and older versions require at least Java 1.6 and JDBC 4.0."
I found posts via google that suggest hibernate 3.6 supported JDBC3, but I cannot find any official documentation that confirms this.
question: is there a JIRA for work on geofence's own modules (not the ones in geoserver)?
Regards
Niels
On 02-06-17 11:24, Niels Charlier wrote:
Hello Nuno,
I don't actually know... This is the only information that has been given to me. I could find out though, but I understand you agree with an upgrade in principle.
I cannot find documentation that lists migration issues. I am assuming I will face quite a few issues, but that these can be resolved. I am hoping that the test coverage is sufficient, so that if I can make all the tests work again I can assume that it works...
Regards
Niels
GeoFence uses GitHub issues: https://github.com/geoserver/geofence/issues
So at least JDBC 4.0 is required:
https://jdbc.postgresql.org/download.html#archived
http://www.oracle.com/technetwork/database/features/jdbc/index-091264.html
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
question: is there a JIRA for work on geofence’s own modules (not the ones in geoserver)?
Regards
Niels
Hello Nuno,
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
please also note that, on top of hibernate, GeoFence relies heavily on the
generic-dao library (com.googlecode.genericdao:dao version 1.1.0), so it
should also be checked that it is compatible with the hibernate version we'll
want to use.
The lib seems to have been automatically migrated here:
   https://github.com/based2/hibernate-generic-dao
but there's no recent activity on it.
Replacing that library in GeoFence will require a major rework of the
persistence and service modules.
   Emanuele
> ones in geoserver)?
> Regards
> Niels
>> Hello Nuno,
>>> Hi,
>>> ...) which versions will still compatible ? Hibernate rely on the JDBC
>> 4.2.
>> 4.0."
>> Regards
>> Niels
>> ------ Check out the vibrant tech community on one of the world's most
>> engaging tech sites, Slashdot.org!http://sdm.link/slashdot
>> _______________________________________________
Visit http://goo.gl/NWWaa2 for more information.
Ing. Emanuele Tajariol
Technical Lead
mob: +39 380 2116282
Right... This project seems to have been abandoned.
Wow, major rework indeed... but unavoidable :confused: We will need to get rid of this library if we ever want to upgrade hibernate.
Thanks for that important point, Emanuele.
Regards
Niels
On 05-06-17 11:08, Emanuele Tajariol wrote:
want to use.
    Emanuele
ones in geoserver)?
Regards
Niels
Hello Nuno,
4.2.
4.0."
Regards
Niels
Emanuele,
I see three possible options:
1) Switch to another framework, in which case spring data seems to be the obvious choice to me. There are two sub-options
(a) make a whole new DAO api and immediately modify all the services to the work with it -> major!
(b) create a deprecated bridging API so that the services code do not all need to be changed at once
2) Internalise the generic DAO, which would essentially mean copy-paste a lot of code from the hibernate-generic-dao library and then I wonder if we wouldn't just better go for option 3
3) patch the existing library to work with the new hibernate. This could potentially actually be the least work of all - possibly not much is needed to make it work again, but I'd need more analysis. Then again, it must be abandoned for a reason?
DO you agree with my analysis? What do you think of these options? What is your preference?
Regards
Niels
want to use.
    Emanuele
ones in geoserver)?
Regards
Niels
Hello Nuno,
4.2.
4.0."
Regards
Niels
Hello Emanuele,
Have you had the chance to look at this email?
We would like to upgrade to Hibernate 5.2 after all, which means JDBC 4.2. Would that be okay?
Thanks in advance!
Kind Regards
Niels
On 08-06-17 17:54, Niels Charlier wrote:
Emanuele,
Regards
Niels
want to use.
    Emanuele
ones in geoserver)?
Regards
Niels
Hello Nuno,
4.2.
4.0."
Regards
Niels
Hi Niels,
Since the DAO module shall work both inside the standalone GeoFence version
and within GeoServer (when using the geofence-server plugin), I'd go with the
full removal of the genericdao library, and use the same libs GeoServer is
already using.
If GeoServer is not using anything particular, we may just go and see if we
can simply use the hibernate API to do most of the filtering work that is done
using the genericdao lib.
1b) requires some more work that will eventually be dropped, and probably the
work on the fixing needed to make the bridging API work will be comparable to
the 1a) option.
I wouldn't pick 2) or 3), since it means to become the maintainer of a quite
unrelated project :slight_smile:
I guess that the 1a) option may be the cheaper in the long run.
   Emanuele
Alle 17:54:30 di Thursday 8 June 2017, Niels Charlier ha scritto:
Emanuele,
is your preference?
Regards
Niels
> Hi all,
> the generic-dao library (com.googlecode.genericdao:dao version 1.1.0),
> so it should also be checked that it is compatible with the hibernate
> version we'll want to use.
> Cheers,
> Emanuele
>> ml
>>> ones in geoserver)?
>>> Regards
>>> Niels
>>>> Hello Nuno,
>>>>> Hi,
>>>>> 5.x ?
>>>> 4.2.
>>>> 4.0."
>>>> Regards
>>>> Niels
>>>> -- ------ Check out the vibrant tech community on one of the world's
>>>> most engaging tech sites, Slashdot.org!http://sdm.link/slashdot
>>> -- ----- Check out the vibrant tech community on one of the world's
>>> most engaging tech sites, Slashdot.org! http://sdm.link/slashdot
Technical Lead
Hello Emanuele,
Thanks for your comments. We feel the same way about option (3), although I feel it would be the easiest in short run, our concern is indeed that we will end up needing to support this library by ourselves.
What about this question:
We would like to upgrade to Hibernate 5.2 after all, which means moving to JDBC 4.2. Would that be okay for your end?
Kind Regards
Niels
On 30-06-17 19:28, Emanuele Tajariol wrote:
Hi Niels,
already using.
the 1a) option.
    Emanuele
Emanuele,
is your preference?
Regards
Niels
     Emanuele
ml
ones in geoserver)?
Regards
Niels
Hello Nuno,
5.x ?
4.2.
4.0."
Regards
Niels
