[Geoserver-devel] upgrade postgresql JDBC driver to 42.1.1 (full binary xfer)
For GeoGig, we noticed that the latest Postgresql JDBC driver (42.1.1) now allows full-binary data transfer. This is better than 25% less bandwidth than Base64 encoding!
I’d like to update the pom.xml from 9.4.1211 to 42.1.1.
NOTE: PostGIS could be upgraded to use this as its a big win for a remote (networked) database.
Note: you must use a prepared statement!
https://jdbc.postgresql.org/download.html
From the pom.xml;
<postgresql.jdbc.version>9.4.1211</postgresql.jdbc.version>
Comments?
Dave
Dave,
with this upgrade, a full GeoTools build with online jdbc-postgis tests, GeoServer build, community module compilation, and app-schema online tests against postgis all pass. I also confirmed that the correct jar is included in the assembled war and zip files.
Jira issue: https://osgeo-org.atlassian.net/browse/GEOT-5741
Pull request for master: https://github.com/geotools/geotools/pull/1605
Tested on debian unstable amd64:
postgresql-9.6 9.6.3-3 amd64
postgresql-9.6-postgis-2.3 2.3.1+dfsg-2 amd64
It would be good if someone could test this upgrade against an older postgresql (especially 8).
$ mvn -version
Apache Maven 3.5.0 (ff8f5e7444045639af65f6095c62210b5713f426; 2017-04-04T07:39:06+12:00)
Maven home: /home/ben/java/maven
Java version: 1.8.0_131, vendor: Oracle Corporation
Java home: /usr/lib/jvm/java-8-openjdk-amd64/jre
Default locale: en_GB, platform encoding: UTF-8
OS name: "linux", version: "4.9.0-3-amd64", arch: "amd64", family: "unix"
Kind regards,
Ben.
On 30/05/17 09:22, Dave Blasby wrote:
I'd like to update the pom.xml from 9.4.1211 to 42.1.1.
From the pom.xml;
Comments?
Dave
Check out the vibrant tech community on one of the world's most
GeoTools-Devel mailing list
GeoTools-Devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
So, are you proposing just an upgrade of the driver, or are you also going to change the postgis store code to leverage the
binary transfer?
On Mon, May 29, 2017 at 11:22 PM, Dave Blasby <dblasby@anonymised.com> wrote:
From the pom.xml;
Comments?
Dave
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi, Andrea,
Only updating the driver version.
I can work with the PostGIS maintainer to get it in - it’s fairly easy (just need to ensure that you are using prepared statements). The difficulty is in verifying it’s working - you don’t really have any access to what’s happening in the driver. For GeoGig, I verified using wireshark (you can also verify by stepping into the driver).
Dave
On Tue, May 30, 2017 at 1:03 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
binary transfer?
From the pom.xml;
Comments?
Dave
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Hi, Ben,
Thanks for putting the PR together and making sure everything was tested (esp online tests).
WRT postgresql version support, I found this in the release notes for 42.0.0;
  • Support for PostgreSQL versions below 8.2 was dropped
Dave
On Mon, May 29, 2017 at 8:31 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Dave,
$ mvn -version
OS name: “linux”, version: “4.9.0-3-amd64”, arch: “amd64”, family: “unix”
Kind regards,
Ben.
From the pom.xml;
Comments?
Dave
GeoTools-Devel@anonymised.comge.net
Director
Transient Software Limited <http://transient.nz/>
New Zealand
On Tue, May 30, 2017 at 7:01 PM, Dave Blasby <dblasby@anonymised.com>
wrote:
Hi, Andrea,
I can work with the PostGIS maintainer to get it in - it's fairly easy
Maintainer eh? It used to be me and Justin.
When you say "ensure that you are using prepared statements" is that only
to get the actual binary transfer, or it would just
break?
And does that require some specific version of postgresql?
The 25% less transfer is interesting, wondering if you have been looking at
TWKB, that should provide greater savings (with
some potential loss of precision).
Ing. Andrea Aime
@geowolf
Technical Lead
Hi, Andrea,
if you aren’t using prepared statements, it doesn’t know that the data is binary and it will “kick back” to the standard encoding (with a lot of “\001”-like in the text). It will work, but you are at approximately 300% overhead.
As mentioned, above, I believe it works for PostgreSQL 8.2+ (December 2006).
I did take a look at TWKB, but for GeoGig purposes, the loss of precision is a problem. However, I am planning to look into it - it makes huge space savings when you are looking at already-reduced-precision geometries.
I was also going to look at TWKB-like lossless encoding (ie. Double#doubleToLongBits() and then using a TWKB-like int-diff encoding). However, it’s likely better to just LZ4 the WKB. When I do the testing, I’ll let you know what happens.
Either way, encoding TWKB as real “binary” (wrt Base64) will be another big win.
Dave
On Tue, May 30, 2017 at 10:43 AM, Andrea Aime <andrea.aime@anonymised.com…> wrote:
On Tue, May 30, 2017 at 7:01 PM, Dave Blasby <dblasby@anonymised.com> wrote:
Hi, Andrea,
When you say “ensure that you are using prepared statements” is that only to get the actual binary transfer, or it would just
break?
The 25% less transfer is interesting, wondering if you have been looking at TWKB, that should provide greater savings (with
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks, Dave. That is a good point. I think 8.2 came out in 2006 or so. Last release for 8.1 was in 2010.
Developers, are we happy to drop support for PostgreSQL below 8.2?
Kind regards,
Ben.
On 31/05/17 05:43, Dave Blasby wrote:
Hi, Ben,
(esp online tests).
42.0.0;
   - Support for PostgreSQL versions below 8.2 was dropped
Dave
wrote:
Dave,
$ mvn -version
Kind regards,
Ben.
From the pom.xml;
Comments?
Dave
Director
New Zealand
Director
New Zealand
In general I'd say yes, may be best to check what Centos is shipping with
currently as they are often far behind the curve
Ian
I don’t know about CentOS, but though I’d look for the oldest supported Ubuntu server, 12.04 [1], it seems it it was shipping with 8.4,
so good from this side
[1] Still supported only for paying customers but also provided as the default choice on Azure
GeoTools-Devel@anonymised.com66…sourceforge.net
In general I’d say yes, may be best to check what Centos is shipping with currently as they are often far behind the curve
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
Looks like Centos go back to 8.0 but recommend 9.2 (https://yum.postgresql.org/) so probably ok.
Ian
On 31 May 2017 at 09:12, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, May 31, 2017 at 9:46 AM, Ian Turton <ijturton@anonymised.com.> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Ian
Ian Turton
CentOS 6 has 8.4.20:
http://mirror.centos.org/centos/6/os/x86_64/Packages/postgresql-8.4.20-7.el6.x86_64.rpm
CentOS 5 has 8.1.23, but CentOS 5 is past end of life:
http://vault.centos.org/5.11/os/x86_64/CentOS/postgresql-8.1.23-10.el5_10.x86_64.rpm
Kind regards,
Ben.
Ian
I don't know about CentOS, but though I'd look for the oldest supported
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
phone: +39 0584 962313 <+39%200584%20962313>
fax: +39 0584 1660272 <+39%200584%20166%200272>
mob: +39 339 8844549 <+39%20339%20884%204549>
Director
New Zealand
I was hoping we could merge Ben’s PR, which updates the driver version.
Dave
On Wed, May 31, 2017 at 4:08 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Kind regards,
Ben.
Ian
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
Director
New Zealand
I have no particular object, but not going to take responsibility for it. Merge as you see fit
(and handle whatever side effect).
On Tue, Jun 6, 2017 at 6:54 PM, Dave Blasby <dblasby@anonymised.com> wrote:
Dave
Kind regards,
Ben.
Ian
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
Director
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Merged on master.
Kind regards,
Ben.
On 07/06/17 04:56, Andrea Aime wrote:
wrote:
I was hoping we could merge Ben's PR, which updates the driver version.
Dave
Kind regards,
Ben.
Ian
wrote:
with
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
stesso,
The information in this message and/or attachments, is intended solely
for
the attention and use of the named addressee(s) and may be confidential
or
Code).Any use not in accord with its purpose, any disclosure,
reproduction,
copying, distribution, or either dissemination, either whole or
partial, is
or
Director
New Zealand
Director
New Zealand
