[Geoserver-devel] Upgrading formatter plugin to the latest version (compatible with Java 8)?
I have setup a draft PR for GeoTools showing the results of formatting using
the latest Java 8 compatible version of the Google Java formatter (they eventually
started requiring Java 11 as the minimum, this one is the latest that’s still Java 8 compatible):
https://github.com/geotools/geotools/pull/3697
I like how the streams are formatter in a bit more compact way, don’t mind the different
formatting of long/complex annotations.
What do you think?
If approved, I’ll make sure to apply the formatting in all projects, and all active branches, at the same time, so as to reduce PR backport efforts.
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Go for it! :smiley:
Jody Garnett
After sending the mail I found the newer version of the plugin emits some pretty annoying logging.
It has been fixed on the latest releases, requiring Java 11, while the series supporting Java 8 seems to be dead by now… options I see:
  • The logging fix is trivial, I could apply the patch on the 2.9.x branch and just make a custom release for us
  • Switch to another formatter, “spotless”, that allows to freely choose the version of google-java-format to be used… that would require new tests, and docs updates
    I’ll think about it. Any strong preference?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
