[Geoserver-devel] Upgrading JDBCConfig
as a related concern to the work we’re doing these days, I’ve noticed that for
JDBCConfig to notice the new delegated/nested properties we are adding,
we basically have to re-import the configuration from the data directory.
Which is not a problem for us, but what will happen to those that already
have a real large catalog inside JDBCConfig?
I guess there should be some way to updated the various meta tables, empty
object_property, and then have it re-populated from the object table somehow.
As said, no big deal for us, and maybe no big deal in general since the
module is unsupported anyways but… I guess someone out there might be
actually using it, and having to loose the entire configuration because of
structure updates might be rather nasty.
Ideas?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Yeah, I have thought about this before. What i was thinking was that we would have a metadata table stored by jdbc config to store various types of stuff. One of the things could be a version of the data directory. However, I am not sure if we have anything that indicates that. I was thinking we could add a simple number and increment it everytime the configuration changes. Anyways, might be some issues with that but that was my initial thinking on the issue.
On Tue, Nov 18, 2014 at 3:33 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ideas?
Ing. Andrea Aime
@geowolf
Technical Lead
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=157005751&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Justin Deoliveira
VP Engineering | Boundless
jdeolive@anonymised.com
@boundlessgeo
I was thinking along the same line. And also for the GWC config that Andrea mentioned was making a full scan at start up.
Basically having a “version” that’s checked at startup, and calls an upgrade function only if the current version is lower than it should be.
On Tue, Nov 18, 2014 at 1:18 PM, Justin Deoliveira <jdeolive@anonymised.com9…> wrote:
Ideas?
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
@boundlessgeo
Gabriel Roldán
Software Developer | Boundless
groldan@anonymised.com
@boundlessgeo
On Tue, Nov 18, 2014 at 5:18 PM, Justin Deoliveira <
Right, that is one concern, changes in the data model should be reflected
in the persisted vision of it (objects and direct properties) that
JDBCConfig has of the data model.
And that's one thing... the other thing is that JDBCConfig itself could
have some new nested property, or a new handling for a
derived property, and so on.
So I guess if we go by the version numbers, we'd need two, one for the
GeoServer object model, and one for the JDBCConfig
interpretation of it
I'm just worried about the GeoServer object model part, will people
remember to update the number when new direct
fields, or new objects are added into the model?
Maybe JDBCConfig could do a hash of the objects and direct fields, and
compare with one stored in the database.
For nested fields we could also do the same... the issue is with the
derived properties, which are handled programmatically...
so yeah, there we'd probably need a a version number of sorts, hoping that
whoever works on JDBCconfig remembers
to update it?
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Nov 18, 2014 at 9:53 AM, Andrea Aime <andrea.aime@anonymised.com>
to update it?
Well I think it kind of happens infrequently enough to be manageable, but
yeah something we would have to remember. But yeah, some sort of hash to
automatically detect would be ideal if it worked.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
VP Engineering | Boundless <http://boundlessgeo.com/&gt;
@boundlessgeo <http://twitter.com/boundlessgeo/&gt;
On Wed, Nov 19, 2014 at 4:25 PM, Justin Deoliveira <
JDBCConfig takes the classes in org.geosever.catalog.impl.ClassMappings,
and uses reflection to find
all bean properties, that's how the "automatic" property indexing is
created (then there is a nested_properties.properties
file for nested properties JDCBConfig wants to index, and some code that
does magic for certain properties, picking
them in different places).
So... limited to what it automatically extracted from the object model, if
we picked the list of class and property names
and made a SHA1 digest of them, we should have a reliable digest that
changes any time any of CatalogInfo subclasses
changes (property wise, that is)
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Nov 19, 2014 at 8:29 AM, Andrea Aime <andrea.aime@anonymised.com>
but yeah something we would have to remember. But yeah, some sort of hash
to automatically detect would be ideal if it worked.
Makes sense. Definitely +1 on that approach.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
