[Geoserver-devel] Upgrading to the latest version of the Google Java Format plugin?
Hi (sorry for the cross post, issue involves all projects),
we are a few versions behind with the format plugin, tried out the latest one here:
https://github.com/geotools/geotools/pull/2736
There are not many changes, believe this upgrade of the Maven plugin gives us the
changes included in the google-java-format library 1.6 and 1.7:
https://github.com/google/google-java-format/releases
I’m not pressing for an upgrade, the changes are small, will reduce line count a bit… meh, maybe not,
but happy to hear your opinion
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I would rather stay current, as folks using IDE integration will grab “the latest”
Jody Garnett
