hello all,
I’m trying to upload a netcdf file to geoserver, without success.
I did the following steps:
- create the workspace without problem
- then the PUT request for the file, following the doc https://docs.geoserver.org/latest/en/api/#/latest/en/api/1.0.0/coveragestores.yaml:
curl -u admin:geoserver -v -X PUT “http://localhost/geoserver/rest/workspaces/WP1/coveragestores/CV1/file.netcdf?filename=%2Fhome%2Flocal%2Ftest1.zip” -H “accept: application/json” -H “content-type: application/json”
the file test1.zip, located in /home/local is a zipped netcdf file (zip test1.zip myfile.nc) and is readable by all.
The answer is 500
The logs file contains:
[org.geoserver.rest.RestException 500 INTERNAL_SERVER_ERROR: Could not acquire reader for coverage.]
2019-12-03 15:38:02,322 INFO [rest.catalog] - Using existing coverage store: CV1
2019-12-03 15:38:02,324 WARN [io.netcdf] - unable to connect to the specified source file:/opt/tomcat/webapps/geoserver/data/data/WP1/CV1/var/tmp/testnm.zip
org.geotools.data.DataSourceException: unable to connect to the specified source file:/opt/tomcat/webapps/geoserver/data/data/WP1/CV1/var/tmp/testnm.zip
the file in tomcat dir is empty:
-rw-r----- 1 tomcat8 tomcat8 0 Dec 3 15:38 /opt/tomcat/webapps/geoserver/data/data/WP1/CV1/var/tmp/testnm.zip
I am also able to to the same process using the webgui and it works well. Only the REST API is a problem.
Anybody can help?
Thanks in advance
Natalia
Natalia Moraga
Géographe / 07 66 23 87 33
