Hi list,
I have been trying without real success to upload netCDF files in GeoServer throungh REST interface. The file contains only one netCDF file, without any subsets or bands. So it is a pretty simple netCDF file.
I have tried the following two methods:
- curl -u admin:geoserver -v -POST -H “Content-type: text/xml” -d “stwstrueNetCDFd:\path_to_netcdf\data.nc” “http://localhost:8080/geoserver/rest/workspaces/ws/coveragestores?configure=all”
I get the following error message: 500 Internal Server Error.
- curl -v -u admin:geoserver -XPUT -H “Content-type:application/zip” --data-binary @d:\path_to netcdf\data.zip http://localhost:8080/geoserver/rest/workspaces/ws/coveragestores/st/file.netcdf
I get the following error message: 500 Internal Server Error Error occured unzipping fileroot
Any ideas or suggestions to solve this issue are more than welcome.
Kind regards,
Corina
First of all, this is a question for the user list, not the devel list, so you will probably have better luck asking there.
Second, have you looked at the REST docs? Based on what I see there, you probably will need to make two requests - first POST of the configuration to “/workspaces/{workspace}/coveragestores” to create the store, then second PUT the file to “/workspaces/{workspace}/coveragestores/{store}/{method}.{format}” to add the file to the store.
See http://docs.geoserver.org/api/#/1.0.0/coveragestores.yaml for more details on each of these requests.
Torben
On Mon, Jan 8, 2018 at 7:29 AM, Corina Tudorache via Geoserver-devel <geoserver-devel@lists.sourceforge.net> wrote:
Hi list,
Kind regards,
Corina
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
