I think it would be the best to add a method to the GeoServerSecurityManager to check if there is an anonymous authentication.
would be fine.
On Wed, Oct 22, 2014 at 5:37 PM, Ian Schneider <ischneider@anonymised.com> wrote:
FWIW, I think the reason the AnonymousGeoNodeAuthenticationToken is extending UsernamePasswordAuthenticationToken is to hold the cookie value that ties the anonymous user to a Django session.
It seems like this could be done differently for sure, especially to play well with the proposed functionality or other security aspects that would (logically) expect an instanceof AnonymousAuthenticationToken check to work.
Thanks for pointing this out
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
On Wed, Oct 22, 2014 at 6:52 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Christian,
your comment makes me think GeoNode should rethink the way they handle
user authentication.
Regardless, what about my question? How to best check if the user is the anonymous one?
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://p.sf.net/sfu/Zoho
Geoserver-devel mailing list
Ian Schneider
Software Engineer | Boundless
1-877-673-6436
@boundlessgeo
On Wed, Oct 22, 2014 at 2:45 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Strange
Looking at
https://github.com/GeoNode/geoserver-geonode-ext/blob/master/src/main/java/org/geonode/security/AnonymousGeoNodeAuthenticationToken.java
I am asking me two questions
- Credentials for an anonymous user ?
- An individual user name for an anonymous user ?
We solve the problem with
GeoServerUser.createAnonymous()
At a minimum I think they should use
org.springframework.security.authentication.AnonymousAuthenticationToken
and we can check with
SecurityContextHolder.getContext().getAuthentication()
Just my 2 cents
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Wed, Oct 22, 2014 at 2:14 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Oct 22, 2014 at 1:12 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Here: https://github.com/GeoNode/geoserver-geonode-ext
It seems to be they are implementing the standard authentication java interfaces
to have GeoServer use GeoNode as the user and authentication source:
https://github.com/GeoNode/geoserver-geonode-ext/tree/master/src/main/java/org/geonode/security
Ing. Andrea Aime
@geowolf
Technical Lead
However sometimes we do have the actual user logging in, in that case
I believe we should use that to drive the limits instead of a cookie.
However… how does one know if the user is the anonymous one?
Just checking if the authentication is a AnonymousAuthenticationToken
seems a bit weak, I’ve for example noticed that GeoNode has
its own AnonymousGeoNodeAuthenticationToken which is, for some
strange reason, a subclass of UsernamePasswordAuthenticationToken
Not sure how to understand. Does GeoNeode extend the Geoserver code ?. I do not know Geonode but how is the class
AnonymousGeoNodeAuthenticationToken injected into GeoServer ?
