[Geoserver-devel] user interface irc
As Chris mentioned earlier we will have an irc about user interfaces in a little bit.
Our current system combines three functions:
- reading in the xml files
- holding the configuration information
- data binding for the application
I would much rather have a separate in memory configuration model that would could code our user interface against.
What I have figured out so far:
- we are not commited to using struts (apparently we just have the jar for historical reasons)
The only advantage I could see to using struts would be that it would force us to keep a nice model-view-controller separation. The downside is that it would be yet another thing to learn.
A quick walk through the code reveals the following information being maintained by the configuration process: ( I am sure I have missed some but it is a starting point)
ServerConfig:
    * root directory
GlobalConfig:
    * global.maxFeatures: int (default 2000 )
    * global.level: Level (default same as org.vfny.geoserver)
    * global.verbose: boolean (default true)
    * global.numDecimals: int (default 8)
    * global.base: URL (default httpd:/localhost:8080/)
    * global.schemaBase (default httpd:/localhost:8080/schema)
    * global.charset: Charset (default ISO-8859-1)
Catalog Config: (this appears to almost "be" the application - holds live data connections)
    * namespace.uri: String
    * namespace.default: boolean (default false, true if only one namespace)
    * datastore.id: String
    * datastore.enabled: boolean (default true)
    * datastore.title: String
    * datastore.abstract: String
    * datastore.featuretype.srid: int (default 0)
    * datastore.featuretype.numDecimals: int (default 8)
    * datastore.featuretype.bbox: Envelope (default calcuated)
WMS Config:
    * exception formats
    * fixed service name
    * update time
    * wms version
WFS Config:
    * fescribeURL
    * WFS Basic LOC
    * WFS CAP LOC
    * WFS Folder
Common to WMS and WFS:
    * enabled
    * onlineResource
    * serviceType
    * URL
    * abstract
    * access Constraints
    * fees
    * keywords
    * maintainer
    * name
    * title
Validation Config:
    * Validation Plug-Ins - xml file for each Validation Java Bean
          o validation.plugIn: Bean (Class required )
          o validation.plugIn.description: (String optional )
          o validation.plugIn.defaults: (Map optional )
    * Directory of XML based validation tests
          o tests: List of tests
          o tests.test: plugIn (String required)
          o tests.test.description: definition (Map optional)
