[Geoserver-devel] using CUDA or OpenCL for geoprocessing?
Hello developer list,
Is there a gain to implement certain geoprocessing algorithms for CUDA or OpenCL? I was asked to do so and I am not shure if this would actually give a huge performance gain compared to the not trivial way to implement it.
What do you think? Are there certain types of geoprocesses where it would perform significantly better? Do you have hints for a novice programmer where to start?
yours,
Florian
Ciao Florian,
your question is too broad IMHO.
We are doing some geoprocessing in CUDA (not OpenCL at this stage) and
in certain cases the performance gain is quite stunning.
Baseline is as follows:
- if you are going to process data that fits into the video card
memory (e.g. few GB size) with a complex parallelizable then the GPU
can speed things up
- if your data is much bigger than what can fit into the video card
you may want to look at a map/reduce approach (where PGU can still
play a role on the single job prior to reduce)
- if your data is small but you do the same processing many times over
time then GPU might not be worth it
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Thu, Feb 25, 2016 at 10:23 AM, Florian Hoedt <gannebamm@anonymised.com> wrote:
where to start?
yours,
Florian
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-devel mailing list
