[Geoserver-devel] Using REST examples
I'm starting with REST, I developed the hello_rest example, I have tried it
from eclipse without problems, but could use the example from a web
browser?.
Try the URL http://localhost:8080/geoserver/rest/hello.txt and generate an
exception.
Regards.
View this message in context: http://old.nabble.com/Using-REST-examples-tp27256799p27256799.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Micho ha scritto:
browser?.
exception.
Hard to help if you don't provide, at the very least, the full stack trace. Details, we don't have the crystal ball
Andrea Aime
OpenGeo - http://opengeo.org
Oh, sorry, but I don't wnow where is the exception information, in the web
browser only appears
Geoserver Configuration API
    * exception
and the exception text is a link to
http://localhost:8080/geoserver/rest/hello/exception, and this web page is
similar to the previous.
Where can I see the exception information?. I have the development
environment as described in the Geoserver Help, building with Maven, running
with Jetty and Eclipse.
Thanks
Andrea Aime-4 wrote:
Micho ha scritto:
it
browser?.
an
exception.
Andrea Aime
Throughout its 18-year history, RSA Conference consistently attracts the
world's best and brightest in the field, creating opportunities for
Conference
attendees to learn about information security's most important issues
through
interactions with peers, luminaries and emerging and established
companies.
http://p.sf.net/sfu/rsaconf-dev2dev
Geoserver-devel mailing list
View this message in context: http://old.nabble.com/Using-REST-examples-tp27256799p27258776.html
It is most likely that your hello_rest module is not on the classpath. In eclipse view the properties of the web-app project. Go to java build path and then projects and verify that the hello_rest module is on the classpath.
-Justin
     * exception
Thanks
Micho ha scritto:
it
browser?.
an
exception.
Andrea Aime
Conference
through
companies.
Justin Deoliveira
Ok Justin, that was the problem, now works perfectly.
Thanks.
classpath.
-Justin
web
     * exception
is
running
Thanks
Micho ha scritto:
tried
it
browser?.
an
exception.
Andrea Aime
Conference
through
companies.
Justin Deoliveira
Conference
through
companies.
View this message in context: http://old.nabble.com/Using-REST-examples-tp27256799p27320459.html
