[Geoserver-devel] Variable substitution for ColorMapEntry attributes
I would like to introduce the possibility to use CQL expressions to specify the value of some attributes of ColorMapEntry SLD tags in raster symbolizers.
My purpose is to be able to use values from WMS requests (specifically variables in the ENV parameter) to dynamically specify those entries attributes in each request.
I would use the already used ${…expression…} syntax for expressions:
An example:
In the WMS request I would specify the env parameter as:
env=low:10;medium:100;high:1000
For my use case, the expression support is needed only for the quantity attribute, but since I am working on it, I would extend it to all the ColorMapEntry attributes, for completeness.
What do you think?
Mauro
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
On Wed, Mar 18, 2015 at 1:46 PM, Mauro Bartolomeoli <
mauro.bartolomeoli@anonymised.com> wrote:
symbolizers.
I would use the already used ${...expression...} syntax for expressions:
An example:
<ColorMap type="intervals" extended="true">
    <ColorMapEntry color="#FF0000" quantity="0.00000000001" label="None"
opacity="0"/>
    <ColorMapEntry color="#00FF00" quantity="${env('low',3)}" label="Low"
opacity="1"/>
    <ColorMapEntry color="#FFFF00" quantity="${env('medium',10)}"
label="Medium" opacity="1"/>
    <ColorMapEntry color="#FF0000" quantity="${env('high',1000)}"
label="High" opacity="1"/>
</ColorMap>
What do you think?
Seems to be it's well aligned with other changes we made in the past where
OGC restrictions were lifted/relaxed to that
we could use expression instead of Literal or PropertyName.
I beleive this is going to break the raster symbolizer interfaces
(backwards incompatible change), can you confirm?
If so we need a proposal
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
No, I don’t think it’s needed, I am only going to change the SLDColorMapBuilder class, where it’s extracting the attribute values, to enable recognition / parsing / evaluation of an eventual cql filter.
After that I am going to do a similar change to support this syntax for GetLegendGraphic calls.
Thanks
Mauro
Seems to be it’s well aligned with other changes we made in the past where OGC restrictions were lifted/relaxed to that
I beleive this is going to break the raster symbolizer interfaces (backwards incompatible change), can you confirm?
@mauro_bart
On Wed, Mar 18, 2015 at 4:05 PM, Mauro Bartolomeoli <
No, I don't think it's needed, I am only going to change the
SLDColorMapBuilder class, where it's extracting the attribute values, to
Oh ok, se ColorMapEntry already supports expression for Quantity.... but we
are parsing it as a literal, e.g., from the sldparser:
        if (atts.getNamedItem(colorMapQuantityString) != null) {
            symbol
.setQuantity(ff.literal(atts.getNamedItem(colorMapQuantityString)
                            .getNodeValue()));
Oh, but I see what you mean, you want to keep it as a string, and if it's a
string instead of a number,
do CQL parsing of it inside SLDColorMapBuilder.
Hum... well, it's similar to what we did for the dynamic symbolizers, as
the sld syntax does not really
allow for a full ogc expression there anyways
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
Yes, that’s exactly my approach.
Mauro
Oh, but I see what you mean, you want to keep it as a string, and if it’s a string instead of a number,
Hum… well, it’s similar to what we did for the dynamic symbolizers, as the sld syntax does not really
@mauro_bart
Ciao Mauro,
a couple of things:
-1- I would advise talking to Daniele about the Dynamic ColorMaps
-2- It would be good if we could take coverage statistics into account
somehow in order to have styles that adapt to the coverage dynamic
itself.
Let me know your toughts about this.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Wed, Mar 18, 2015 at 5:41 PM, Mauro Bartolomeoli
<mauro.bartolomeoli@anonymised.com> wrote:
Hi Andrea,
Yes, that's exactly my approach.
Mauro
@mauro_bart
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
Dive into the World of Parallel Programming The Go Parallel Website,
sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for
all
things parallel software development, from weekly thought leadership blogs
to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
GeoTools-Devel mailing list
GeoTools-Devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
2015-03-18 20:14 GMT+01:00 Simone Giannecchini <simone.giannecchini@anonymised.com>:
Ciao Mauro,
a couple of things:
This community module seems to be missing a couple of things to replace what I need to do:
  • ability to specify a list of values instead of the min - max values only
  • ability to assign labels to color map entries
itself.
From what I see in dynamic color maps documentation (http://docs.geoserver.org/latest/en/user/community/colormap/index.html) , they are already taken into account (only if the coverage satisfies certain requirements like having an auxiliary files generated through GDAL and being a mosaic) using a specific function (gridCoverageStats). Probably we could:
  • port the function out of the community module and make it available in the core
  • make it work on other types of coverages (like simple geotiffs)
  • find the way to avoid having to use gdal to generate statistics
In general, I think that adapting the community extension to do what I need with my patch is a different kind of work, with different impact on the codebase, so I would, in any case eventually do both in parallel. I mean: my proposal is a quick (but not dirty) improvement that allows a small amount of dinamicity in color maps without adding extensions or community modules and it’s ready now (almost). This does not prevent generalizing the community module to handle more dynamic cases that would in the future cover my use case too.
Mauro
@mauro_bart
