On Tue, May 19, 2015 at 5:37 PM, Sen, Marcus A. <mase@anonymised.com> wrote:
I have been working on https://osgeo-org.atlassian.net/browse/GEOS-6435
as the INSPIRE maintenance group is moving towards including WCS as an
option for download services. Along the way I came across a number of other
changes that seemed worth making to the INSPIRE extension. The actual order
I did these was all mixed up but I've tried to separate them into a
reasonably coherent set of steps. I'd like some advice on whether to make
one big pull request for all the changes or separate them into different
parts as they aren't completely independent.
I have a working branch at
https://github.com/bgsmase/geoserver/tree/temp_inspire_on_master_2 which
contains a series of commits on top of master as follows:
1 - Point to the INSPIRE view schema at
http://inspire.ec.europa.eu/schemas/inspire_vs/1.0/inspire_vs.xsd rather
than copy locally hosted by GeoServer. (Should I file a ticket for this?)
Normally we prefer to point to local hosted schemas, as opposed to remote
ones, because in some enviroments there is just
no internet wide access and this allows clients to still download the
schemas.
Also, OGC has the habit of changing the schemas over time, without changing
the file names, suddenly rendering schema
invalid something that was valid until the day before (which of course
makes it impossible to keep an already deployed production
instance up, the results become invalid overnight without anybody being
notified).
Now, inspire wise I guess we can rule out the restricted enviroments, but
I'm bot sure if INSPIRE is up to the same business as OGC
and changes the schemas in place, without creating a n+1 version (or
n.0.x+1 version).
In general, I'd leave the administration an option to point to the
canonical schemas online, or use the local ones (as we do in WFS
for example).
2 - Miscellaneous tidying up of extended capabilities output including:
Remove unnecessary namespace declarations
Remove unnecessary xsi:type attributes
These are un-necessary... why? Because we derive them by importing the DSL
schema? Or just because they are not used? (sorry to ask, I'm not the
original author of the inspire plugin)
Allow the service MetadataURL/MediaType element to be omitted. It
is optional. I intend to add the full list of 20+ types enumerated in the
INSPIRE schema later. Currently only two options are allowed.
Don't include the extended capabilities element if the mandatory
parameters have not been set.
More tests for different combinations of parameters
(Reluctant to make separate tickets/commits for all these)
I lost you there, the comment in the code says it's not used in download
services, but what about view ones, which we also support as WMS?
3 - Add option to set the SpatialDataSetIdentifier/@metadataURL attribute.
We would like to be able to do this (I could file a ticket for this
specifically).
4 - Add INSPIRE extended capabilities to WCS [GEOS-6435]
Any comments / suggestions on any of the changes and, if they look OK,
should I fold them up into one pull request or separate them along the
items listed above?
About the extra tickets, you might want to make a generic "Assorted inspire
plugin improvements" one, provided you give a detailed
list of what changed, for the release notes and changelogs.
Had a quick look at the patches, from a glance I don't see anything wrong,
but others will probably want to review
once you make a pull request.
About the pull request, please follow our norms, one commit per jira
ticket, with the ticket number and title as the commit message
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit
http://goo.gl/WHKDXT for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
