just curious whether anyone has seen this before: I've created a table with "notes" and "comments" (see creation script below), when I try to add the datastore (with version enable all tables), I get the following:
2007-12-04 16:04:57 EST ERROR: new row for relation "changesets" violates check constraint "enforce_geotype_bbox"
2007-12-04 16:04:57 EST STATEMENT: UPDATE "public"."changesets" SET "bbox" = setSRID('000000000100000000000000000000000000000000'::geometry,4326) WHERE revision = 3
I don't quiet understand how it picks that bbox, how this information is used or whether it is caused by my point geometries below. The tables are defined as follows:
dropdb -U postgres notes
createdb -E UTF8 -U postgres notes
createlang -U postgres plpgsql notes
psql -U postgres -d notes -f /usr/share/postgresql-8.2-postgis/lwpostgis.sql
psql -U postgres -d notes -f /usr/share/postgresql-8.2-postgis/spatial_ref_sys.sql
psql -U postgres -d notes -f create_notes.sql
psql -U postgres -d notes -f create_comments.sql
where create_notes.sql is
CREATE TABLE notes (
gid serial PRIMARY key,
typeid bigint,
username character varying(32),
title character varying(256),
datetime time default now(),
content text,
comments text
INSERT INTO notes (typeid,title,username,content,comments) VALUES(0,'title','username','content','comment');
SELECT AddGeometryColumn('public', 'notes', 'the_geom', 4326, 'POINT', 2);
UPDATE notes SET the_geom = GeometryFromText('POINT (0.0 0.0)',4326) WHERE gid = 1;
and create_comments.sql
CREATE TABLE comments (
gid serial PRIMARY KEY,
notes_gid int,
comment text
INSERT INTO comments (notes_gid,title,username,comment) VALUES(1,'title','username','comment');
SELECT AddGeometryColumn('public', 'comments', 'the_fake_geom', 4326, 'POINT', 2);
UPDATE comments SET the_fake_geom = GeometryFromText('POINT (0.0 0.0)',4326) WHERE gid = 1;
