[Geoserver-devel] Volunteers for GeoTools 23.4, GeoWebCache 1.17.4 and GeoServer 2.17.4 need (December 18th)
we are looking for a volunteer to cut the above releases . Any takers?
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I can do that if someone can help me with the GWC release.
BTW how much work would it be to make the GWC release work like the others?
Ian
Ian Turton
Right now the GWC release uses a ruby script which is a bit tricky to run. The key thing it does which is unusual is open an editor asking the person making the release to update the release notes. If we skipped this step (editing the release notes before hand) release jobs could probably be setup on jenkins.
Indeed we could grep the release notes to ensure they have been edited as part of a release job to prevent mistake.
Jody Garnett
Ian I can help with the GWC release
Jody Garnett
