Hi folks,
I was hoping to call this proposal to a vote:
https://github.com/geoserver/geoserver/wiki/GSIP-160
It’s been updated with the latest feedback from Andrea and Jody and should be ready to go.
Thanks!
-Justin
Hi folks,
Thanks!
-Justin
+1
Ian
On 3 July 2017 at 18:35, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi folks,
Thanks!
-Justin
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ian Turton
Hi Justin,
+1.
On Mon, Jul 3, 2017 at 7:35 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi folks,
Thanks!
-Justin
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
0
Hi folks,
Thanks!
-Justin
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
Hey Justin / Kevin:
Was talking with Kevin last week, he is looking to fine tuning the output of point locations to use for labeling when doing vector tile output.
So you are both working on “calculating a better centroid” - can you share top level format options to avoid duplication?
&format_options=centroid_contain:true;centroid_samples:10;centroid_clip:true
+1 to your GSIP, I do want to hear from Kevin if we can
On 3 July 2017 at 10:35, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi folks,
Thanks!
-Justin
Jody Garnett
On 2017-07-05 11:56 AM, Jody Garnett wrote:
Hey Justin / Kevin:
output.So you are both working on "calculating a better centroid" - can you
share top level format options to avoid duplication?&format_options=centroid_contain:true;centroid_samples:10;centroid_clip:true
Yes this makes sense, At the moment I'm just working on including
precomputed label points in the vector tiles using the existing labeler,
but it's quite likely that would benefit from this kind of additional
control in future, so it would make sense to do it in a format agnostic
way now (at least in terms of keywords we're adding).
Kevin Michael Smith
<smithkm@anonymised.com>
I kind of disagree with trying to generalize the parameters now… if another format comes along and adds a similar capability will it really have the exact same options with the exact same semantics? I am kind of doubtful.
Unless there is a strong consensus that this has to happen I’m inclined to leave the options as is and KML specific until there is a more concrete need to coalesce them.
Hey Justin / Kevin:
output.So you are both working on “calculating a better centroid” - can you
Yes this makes sense, At the moment I’m just working on including
but it’s quite likely that would benefit from this kind of additional
way now (at least in terms of keywords we’re adding).–
Kevin Michael Smith
<smithkm@anonymised.com…>
If you don't think vector tiles label points are relevant that's good
enough for me. I just want to watch out for corners we might paint
ourselves into.
+1
kind of doubtful.Unless there is a strong consensus that this has to happen I’m
more concrete need to coalesce them.On Wed, Jul 5, 2017 at 1:29 PM Kevin Smith <smithkm@anonymised.com
<mailto:smithkm@anonymised.com>> wrote:On 2017-07-05 11:56 AM, Jody Garnett wrote:
> Hey Justin / Kevin:
> output.
> +1 to your GSIP, I do want to hear from Kevin if we canYes this makes sense, At the moment I'm just working on including
labeler,
agnostic
way now (at least in terms of keywords we're adding).--
Kevin Michael Smith
<smithkm@anonymised.com <mailto:smithkm@anonymised.com>>
Kevin Michael Smith
Thanks to everyone who weighed in on this one, i’ve gone ahead and merged the change and marked the proposal as complete.
One small change though, I found that making the new options to clip and force containment the default behaviour introduced a number of failures in the test cases, some of which are kind of subtle and have the chance of tripping up users as well so I decided to play it safe for now and keep the behaviour as is. So all the new kml centroid options are still opt-in.
On Mon, Jul 10, 2017 at 11:30 AM Kevin Smith <smithkm@anonymised.com> wrote:
If you don’t think vector tiles label points are relevant that’s good enough for me. I just want to watch out for corners we might paint ourselves into.
+1
Hey Justin / Kevin:
Kevin Michael Smith
<smithkm@anonymised.com>-- Kevin Michael Smith [<smithkm@anonymised.com>](mailto:smithkm@anonymised.com)
