Starting to finish off drafts for our latest GeoServer milestone!
If you have a chance I would love any feed back on the attached draft. The attached document will be used to drive our last phase of GeoServer development. It also serves as a good rundown of the recent work in restructuring GeoServer.
If you see any features that you think should be part of the 1.2.0 release please let me know.
(I did take a quick run through the Jira 1.2 wish list)
Jody
PS There is a second document on its way covering feedback from the Web Based User Interface
PPS Table of Contents for the pdf impaired...
2 GEOSERVER CONFIGURATION DESIGN
2.1 DESIGN SUCCESSES
2.2 DESIGN EXTENSIONS
2.2.1 Validation Framework Extension
2.3 DESIGN RECOMMENDATIONS
2.3.1 Centralize Application Logic
2.3.2 Proposed Data Layer
2.3.3 FeatureType Definition
2.3.4 Configure Level of WFS Support
3 GEOSERVER CONFIGURATION IMPLEMENTATION
3.1 IMPLEMENTATION SUCCESS
3.1.1 Removed Dependence on Singletons
3.1.2 Data Transfer Objects
3.1.3 Ported JUMP Network Builder
3.2 IMPLEMENTATION EXTENSIONS
3.2.1 Attribute Based XMLSchema Generation
3.2.2 Handling of Type References
3.3 IMPLEMENTATION RECOMMENDATIONS
3.3.1 Sample Configuration
3.3.2 Phase out the use of Document Object Model XML Parsing
3.3.3 GML Harmonization
3.3.4 Remove Data Transfer Object Delegates
(attachments)
VWFSImplementationReport.pdf (357 KB)
