On Tue, Apr 19, 2016 at 6:50 PM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
One consistent warning in our failed starts on windows and mac is the
following:
WARNING: Module not found [ssl]
I can see this on Linux as well, but the startup works fine. The log indeed
seems to be coming from Jetty,
I believe GeoServer has not even begun to startup when that is logged.
There is a interesting stack overflow discussion here:
http://stackoverflow.com/questions/30162057/module-not-found-protonego-impl-alpn-1-8-0-45-when-running-jetty-from-intellij
Makes me wonder if a further Jetty upgrade is needed to make that one go
away.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
