[Geoserver-devel] Warning to devs: do not use aop:config in spring context
sharing a bit of a horror story here… do not ever try to use something like Spring’s aop:config
in a app-context used by GeoServer, as that will break startup in a most weird way…
basically, when those are available in the spring context, GWC fails to start if the gs-gwc.xml
file is not found, because the GeoServerInitializer are not run… which in turn happens
because GeoServerLoaderProxy.lookupGeoServerLoader ends up forcing the loading
of all beans ahead of time (probably because aop needs to check them in order to apply
the advices).
Soo… just in case you need AOP, instead of the aop:config thing, you can use old style
aop instead (org.springframework.aop.framework.ProxyFactoryBean and friends), which
works…
Cheres
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
