I ran into some failures running the wcs 1.0.0 tests. A few were errors in the tests themselves but a couple of others seem legit:
* wcs1-0-0:describecoverage_operations-describecoverage_response-supportedcrss-rectifiedgrid
This one complains that an srsName attribute is missing on the element:
/CoverageOffering/domainSet/spatialDomain/gml:RectifiedGrid
in a describe coverage request. I patched it by simply adding the attribute, with a value equal to srsName of the Envelope element which is its sibling.
* wcs1-0-0:getcapabilities_operations-getcapabilities_request-section
This test dictates that when a full capabilities request is done (with a root element that contains the service version) that each of the subelements: Service, Capability, and ContentMetadata elements should *not* have a version.
The fix was simply to remove the version attributes on said elements... the motivation being that we never encode these entities in isolation? Does wcs support partial capabilities documents?
* wcs1-0-0:getcoverage_operations-getcoverage_request-each_interpolation_method
This one seemed to be an encoding error, part of the DescribeCoverage response looks like this:
<supportedCRSs>
<requestResponseCRSs>EPSG:4326
</requestResponseCRSs>
</supportedCRSs>
With a space and a newline after the "EPSG:4326". I simply removed the whitespace (at the end of the list) and the newline to make it look like this:
<supportedCRSs>
<requestResponseCRSs>EPSG:4326</requestResponseCRSs>
</supportedCRSs>
And that fixes the test.
So I will go ahead and commit the fixes as they seem pretty minor in both cases. But it woudl be good to have someone review the changes since I am much less confident in changing the coverage stuff.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
