Hi guys,
the new WCS 1.0.0 module using EMF is ready ... what to do now? When,
where and how I can port the stuff home? Actually the code can be
found here https://svn.codehaus.org/geoserver/branches/1.7.x_WCS10_EMF
Alessio.
Eng. Alessio Fabiani
Vice-President /CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 349 8227000
Alessio Fabiani ha scritto:
Hi guys,
I see you've been making fixing related to the CITE tests.
Anyways, since this is a significant change, what about a quick code
review on crucible? Justin can have a look at the bindings, and me
at the coverage related code:
http://crucible.opengeo.org/
(create a new user id, create a new review, go to files, and then
pick up the sources you want us to have a look at).
Once that is done, if WCS tests are passing
and sample requests are working, I personally have no troubles
merging the changes in just before RC1: no, I'm not gone mad,
it's just that I have the impression WCS is not very much used,
and that you are the biggest users of it, so if it suits your
need it'll probably be ok for the other users as well.
Ok,
I have created the reviews on Crucible (hope making no mistakes).
Alessio.
Hi guys,
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
I added a couple of comments. Does crucible notify when review comments are added?
Alessio Fabiani wrote:
Ok,
Alessio.
Hi guys,
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Yep, it does, I received the notifications already
