I’ve been running into an odd test failure in the gs-wcs1_1 module. When I run this test, I get the following exception in testDeferredLoading(org.geoserver.wcs.GetCoverageTest):
org.vfny.geoserver.wcs.WcsException: org.geotools.data.DataSourceException: Unable to create this mosaic
at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:565)
at org.geoserver.wcs.AbstractGetCoverageTest.executeGetCoverageKvp(AbstractGetCoverageTest.java:67)
at org.geoserver.wcs.GetCoverageTest.testDeferredLoading(GetCoverageTest.java:620)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
Caused by: org.geotools.data.DataSourceException: Unable to create this mosaic
at org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1348)
at org.geotools.gce.imagemosaic.RasterLayerResponse.processRequest(RasterLayerResponse.java:1228)
at org.geotools.gce.imagemosaic.RasterLayerResponse.createResponse(RasterLayerResponse.java:1194)
at org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:1157)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:894)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:873)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:807)
at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:243)
at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:233)
at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:358)
… 36 more
Caused by: java.io.IOException: java.lang.NullPointerException
at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.collectGranules(RasterLayerResponse.java:516)
at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.access$2400(RasterLayerResponse.java:332)
at org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.produce(RasterLayerResponse.java:1072)
at org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.access$3100(RasterLayerResponse.java:882)
at org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1296)
… 45 more
Caused by: java.lang.NullPointerException
at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.collectGranules(RasterLayerResponse.java:476)
I get this failure if I run the tests using maven or in eclipse while in debug mode. If I run the tests normally in eclipse, they pass without error.
I’ve had a few other people with similar environments run these tests, and none of them were able to reproduce my issue.
From what I can tell, when the test failure occurs, the RasterLayerResponse$GranualCollector is using a PlanarImage with a null colorModel, which causes the NPE when we try and get the alpha from the colorModel.
Does anyone have an idea why I am getting this failure (and more importantly, why no one else is?)
Torben
