I am looking into the WCS 1.1 test failures and while they are the result of
the KVP parsing changes done to support multiple keys with multiple values,
it is fair to say that before the tests were working by accident.
Right now GeoServer is rightfully complaining that the following request is invalid:
http://localhost:8080/geoserver/ows?service=wcs&request=GetCapabilities&service=WCS
Now, this is happening because:
- the xml config file feeding the CITE test for the WCS server entry points contains
http://localhost:11010/geoserver/ows?service=wcs&version=1.1.1&request=GetCapabilities
however the WCS 1.1 tests asks for the entry point, not the caps document, and
feeds the service and request params by itself - the service param cannot be provided two times, and more importantly, the
value provided in the form configuration file is wrong, since values in a KVP request
are meant to be case sensitive, and the service value for WCS is fixed to ‘WCS’
I was hoping to just fix the issue by setting the entry point url to
Unfortunately it seems the root of the workspace used by the cite tests is not under
version control, as a result it is unreachable:
http://hudson.opengeo.org/hudson/view/cite/job/cite-wcs-1.1-master/ws/
Long story short, it seems to be only someone with direct access to the
build server filesystem can perform the fix.
As a shared good it would be better if the tests was pulling from some developer
accessible version control, but in case this is deemed unsuitable can someone
from OpenGeo fix this file:
http://hudson.opengeo.org/hudson/view/cite/job/cite-wcs-1.1-master/ws/forms/wcs-1.1.1.xml
so that the url contained in it is merely: http://localhost:11010/geoserver/ows?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
