[Geoserver-devel] WCS 1.1 build failures on the hudson server
this morning I took some time to look into the build failures and found
my local build had only a few of the ones reported by the build server.
Nevertheless, I applied a simple patch (actually a simple workaround to make
sure image/tiff is the first output format listed) and got a full pass
of WCS 1.1 on my machine, 157 tests passing.
Now, committed, then forced Hudson to do a normal build, a nightly
build, and then run cite again... and got a slew of failures again.
But on my machine everything is working as expected...
Am I missing some steps/configurations to reproduce what the build
server is doing?
I'm basically running the cite engine with mvn jetty:run-exploded
and hitting GeoServer running wit the WCS 1.1 data directory,
no extra fiddling of any kind.
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Hmmm… looking at the log it does not seem the errors are with the fact that other non geotiff formats are being used:
http://gridlock.opengeo.org:7070/teamengine/viewSessionLog.jsp?session=wcs-1.1.1
In fact many of the errors suggest that the configuration is quite messed up. Here is the interactive log:
I will start up the geoserver manually now in order to test against something live.
-Justin
On Thu, Nov 18, 2010 at 4:12 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
build, and then run cite again… and got a slew of failures again.
But on my machine everything is working as expected…
server is doing?
I’m basically running the cite engine with mvn jetty:run-exploded
Ing. Andrea Aime
fax: +39 0584962313
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today
http://p.sf.net/sfu/msIE9-sfdev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Never mind, this was a problem on the build server with how the data directory was being setup. Laughingly a nonsense data directory was being used and the test suite still passes a bunch of tests :slight_smile:
Anyways, problem should be fixed. If you fire off the cite wcs-1.1 job it should work.
Thanks btw for fixing those issues. We can now turn on the cite wcs job to report failures to the mailing list.
-Justin
On Thu, Nov 18, 2010 at 7:58 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
-Justin
server is doing?
Ing. Andrea Aime
fax: +39 0584962313
Justin Deoliveira
Justin Deoliveira
On Thu, Nov 18, 2010 at 4:04 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Don't get me started, that test suite is really a joke (tests only
formal compliance,
does not actually check GetCoverage results).
should work.
Yup, I see the build is working
Yay!
Ing. Andrea Aime
fax: +39 0584962313
