[Geoserver-devel] WCS 2.0.1 with SCALESIZE [SOLVED]
Hi Andrea,
What spec you are reading? All examples in OGC® Web Coverage Service Interface Standard - Scaling Extension are using the short format
…& SCALEFACTOR=2.0 &…
…& SCALEAXES=i(3.5),j(3.5),k(2.0) &…
…& SCALESIZE=i(1000),j(1000),k(10) &…
…& SCALEEXTENT=i(10:20),j(20:30) &…
or as XML
scal:ScaleToSize
scal:TargetAxisSize
scal:axisi</scal:axis>
scal:targetSize1000</scal:targetSize>
</scal:TargetAxisSize>
scal:TargetAxisSize
scal:axisj</scal:axis>
scal:TargetAxisSize
scal:axisk</scal:axis>
scal:targetSize10</scal:targetSize>
</scal:ScaleToSize>
However, examples are missing reference to how the axis are presented in DescribeCoverage.
The this discussion that I found from the web is in https://groups.google.com/forum/#!msg/rasdaman-users/SBA2SrVapHo/J8POkUVy-iwJ Piero Campanali writes:
However (again), in your examples where scaling is involved, you are going to
target GRID axis, so you shouldn’t really bother about URI identifiers because
GRID axis labels are just arbitrary names: you just should pick what is declared
in the domainSet.
Eventually, assuming your GRID labels are “i j” and “Lat Long” the CRS ones,
what I believe would be correct in the WCS scaling requests is:
:: ScaleFactor=2.0
:: ScaleAxesByFactor=i(2),j(2)
:: ScaleSize=i(1000),j(1000)
:: ScaleExtent=Lat(10,20),Long(20,30)
[or even URI identifiers of Lat and Long]
So Piero believes that ScaleAxesByFactor and ScaleSize should never need anything else than the GRID labels which are used in DescribeCoverage, while ScaleExtent might use either CRS axis labels as used in DescribeCoverage, or URI identifier.
Thinking again about this example in the scaling standard:
If axis in SCALEEXTENT are the CRS axis, then the example feels wrong because at least i and j are not the most common CRS axis labels.
-Jukka Rahkonen-
Lähettäjä: andrea.aime@…403… [mailto:andrea.aime@…403…] Puolesta Andrea Aime
Lähetetty: 22. maaliskuuta 2017 9:41
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen@…4189…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] WCS 2.0.1 with SCALESIZE [SOLVED]
Hi Jukka,
that is actually not clear to me, the examples in the spec that I could find are all using the long format, but I could
not find a specific rule for axis names, or how the labels reported in DescribeCoverage output relate to the
IDs used in requests, since the former always uses short names in the spec, and the latter uses long URI
like ones instead (see the scaling extension).
I am not opposed to also recognize a shorter format, could be one of those "GeoServer not quite fully standard
but handy" relaxed interpretations of the protocol. Or you could just be that the specification it’s inconsistent,
it would make a lot of sense imho if the labels reported in DescribeCoverage had to be used as-is
in GetCovearge.
On Tue, Mar 21, 2017 at 10:04 PM, Rahkonen Jukka (MML) <jukka.rahkonen@…4189…> wrote:
All right, the SCALESIZE axis are output grid axes which are named as i and j in DescribeCoverage
gml:axisLabels>i j</gml:axisLabels
So the E and N which are used for subset are wrong for SCALESIZE
Another thing is that i and j can’t be used as it but they require URI for the axis. So this is a working query:
http://localhost:8080/geoserver/wcs?service=WCS&version=2.0.1&request=GetCoverage&coverageID=sf__sfdem&SUBSET=E(589980,590000)&SUBSET=N(4913700,4923700)&SCALESIZE=http://www.opengis.net/def/axis/OGC/1/i(200),http://www.opengis.net/def/axis/OGC/1/j(200)
Now I wonder if it is necessary and useful to require that long format for axis names. The KVP examples in the Scaling Extension standard are using this short and more human-writable syntax:
-Jukka-
Lähettäjä: Rahkonen Jukka (MML)
Lähetetty: 21. maaliskuuta 2017 20:03
Vastaanottaja: ‘Geoserver-devel’
Aihe: [Geoserver-devel] WCS 2.0.1 with SCALESIZE
Is there something wrong with this GetCoverage?
localhost:8080/geoserver/wcs?service=WCS&version=2.0.1&request=GetCoverage&coverageID=sf__sfdem&SUBSET=E(589980,590000)&SUBSET=N(4913700,4923700)&SCALESIZE=E(200),N(200)
The error from GeoServer 2.11-RC1 is
“ScaleAxisUndefined” locator=“E”>
-Jukka Rahkonen-
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On Wed, Mar 22, 2017 at 4:23 PM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
Hi Andrea,
The one we used when the service was implemented... and there lies the
problem :slight_smile:
The WCS 2.0 was implemented while the specification was still in progress,
and the project/funding ended before the
official release of the spec, so we have been implementing it off some
pre-release drafts.
Feel free to open a ticket to have this aligned with the specification
Ing. Andrea Aime
@geowolf
Technical Lead
