Failed tests: testScaleToSizeXML(org.geoserver.wcs2_0.xml.ScalingExtentionTest): expected:<[image/tiff]> but was:<[application/xml]>
So I am going to guess a nested exception, looking at ares surefire test results:
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 13.563 sec <<< FAILURE!
testScaleToSizeXML(org.geoserver.wcs2_0.xml.ScalingExtentionTest) Time elapsed: 4605 sec <<< FAILURE!
junit.framework.ComparisonFailure: expected:<[image/tiff]> but was:<[application/xml]>
at junit.framework.Assert.assertEquals(Assert.java:100)
at junit.framework.Assert.assertEquals(Assert.java:107)
at junit.framework.TestCase.assertEquals(TestCase.java:269)
at org.geoserver.wcs2_0.xml.ScalingExtentionTest.testScaleToSizeXML(ScalingExtentionTest.java:78)
So not much help, I will reproduce locally and report back. I wonder if there is a good way to report service exceptions consistently in our logs to aid in debugging.
