[Geoserver-devel] WCS Bugs in 1.5.0 Beta 1
Hi list,
just been having a play with the WCS and getting a couple of "interesting" results back (apart from these then it's all looking a very impressive piece of work!)
1: The result of this KVP request (attached a.tif):
http://localhost:8080/geoserver/wcs?service=WCS&request=GetCoverage&Version=1.0.0&coverage=nurc:Arc_Sample&crs=EPSG:4326&&response_crs=EPSG:32626&bbox=9.420000076293944,11.819999694824217,42.20000076293945,43.90000049273173&width=120&height=85&format=GEOTIFF
is different to the result of the example XML GetCoverage request with GEOTIFF instead of TIFF (attached b.tif):
<GetCoverage service="WCS" version="1.0.0"
   xmlns="http://www.opengis.net/wcs&quot;
   xmlns:nurc="http://www.nurc.nato.int"
   xmlns:ogc="http://www.opengis.net/ogc&quot;
   xmlns:gml="http://www.opengis.net/gml&quot;
   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
   xsi:schemaLocation="http://www.opengis.net/wcs http://schemas.opengis.net/wcs/1.0.0/getCoverage.xsd&quot;&gt;
  <sourceCoverage>nurc:Arc_Sample</sourceCoverage>
  <domainSubset>
    <spatialSubset>
      <gml:Envelope srsName="EPSG:4326">
        <gml:pos>9.420000076293944 42.20000076293945</gml:pos>
                 <gml:pos>11.819999694824217 43.90000049273173</gml:pos>
      </gml:Envelope>
      <gml:Grid dimension="2" srsName="EPSG:4326">
        <gml:limits>
          <gml:GridEnvelope>
            <gml:low>0 0</gml:low>
                         <gml:high>120 85</gml:high>
          </gml:GridEnvelope>
        </gml:limits>
      </gml:Grid>
    </spatialSubset>
  </domainSubset>
  <rangeSubset>
    <axisSubset name="Band">
      <singleValue>1</singleValue>
    </axisSubset>
  </rangeSubset>
  <output>
      <crs>EPSG:4326</crs>
      <responseCrs>EPSG:32626</responseCrs>
    <format>GEOTIFF</format>
  </output>
</GetCoverage>
from my reading of the WCS spec then these two requests should be identical (making other KVP requests has also delivered strange, and usually very small results similar to a.tif). It is of course possible that I've misread the spec - in which case can anyone correct my KVP request?
2: According to the spec then response_crs is an optional parameter - if it is missing then the crs-parameter will be used. If I omit response_crs I however get an exception that the requested response_crs is unsupported.
Thanks again for a nice piece of software, and in advance to any responses!
Ed
preagro TP7 - Geodateninfrastruktur
http://www.preagro.de
Universität Rostock
Agrar- und Umweltwissenschaftliche Fakultät
Professur für Geodäsie und Geoinformatik
Justus-von-Liebig-Weg 6
18059 Rostock
Tel: +49 381 498 2164
Fax: +49 381 498 2188
Web: http://www.auf.uni-rostok.de/gg
(attachments)
b.tif (18.7 KB)
a.tif (1.29 KB)
Dear Dr. Edward Nash,
thank you very much for your feedbacks. Actually we have very few of them from users, while they are really useful for our work.
I’ll check those problems to see if there are errors on WCS and, eventually, how to fix them. I’ll reply to you as soon as possible.
Kind regards,
Alessio.
On 1/8/07, Edward Nash <edward.nash@anonymised.com> wrote:
Hi list,
“interesting” results back (apart from these then it’s all looking a
nurc:Arc_Sample
<gml:Envelope srsName=“EPSG:4326”>
gml:pos9.420000076293944 42.20000076293945</gml:pos>
gml:pos11.819999694824217 43.90000049273173</gml:pos>
</gml:Envelope>
<gml:Grid dimension=“2” srsName=“EPSG:4326”>
gml:limits
gml:GridEnvelope
gml:low0 0</gml:low>
gml:high120 85</gml:high>
</gml:GridEnvelope>
</gml:limits>
</gml:Grid>
1
EPSG:4326
EPSG:32626
GEOTIFF
that I’ve misread the spec - in which case can anyone correct my KVP
request?
is unsupported.
Ed
Universität Rostock
18059 Rostock
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-devel mailing list
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
Dear Dr. Edward,
I checked your problems, and I noticed as follows:
1 - Your KVP request is wrong, the right one should be
http://localhost:8080/geoserver/wcs?service=WCS&request=GetCoverage&Version=1.0.0&coverage=nurc:Arc_Sample&crs=EPSG:4326&response_crs=EPSG:32626&bbox=9.420000076293944,42.20000076293945,11.819999694824217,43.90000049273173&width=120&height=85&format=GEOTIFF
NOTE: Make sure to start your Web Container with the Java option -Dorg.geotools.referencing.forceXY=true
2 - I tried to remove the responsecrs parameter and all works fine on my side, the crs is considered as default.
NOTE: is it possible for you compile the GeoServer version on 1.5.x SVN branch? A lot of bugfixes have been committed there recently.
https://svn.codehaus.org/geoserver/branches/1.5.x
Let me know of your progresses and tryes.
Hi list,
nurc:Arc_Sample
</gml:Envelope>
gml:limits
gml:GridEnvelope
</gml:GridEnvelope>
</gml:limits>
</gml:Grid>
1
EPSG:4326
EPSG:32626
GEOTIFF
request?
is unsupported.
Ed
Universität Rostock
18059 Rostock
Should we put out a beta2 release? Generally it's worthwhile if we get to the point where we're wanting people to use SVN so we're sure they're not testing things we've already fixed.
Chris
On 1/8/07, *Edward Nash* <edward.nash@anonymised.com <mailto:edward.nash@anonymised.com>> wrote:
    Hi list,
    <http://localhost:8080/geoserver/wcs?service=WCS&request=GetCoverage&Version=1.0.0&coverage=nurc:Arc_Sample&crs=EPSG:4326&&response_crs=EPSG:32626&bbox=9.420000076293944,11.819999694824217,42.20000076293945,43.90000049273173&width=120&height=85&format=GEOTIFF&gt;
       xmlns=" http://www.opengis.net/wcs&quot;
    http://schemas.opengis.net/wcs/1.0.0/getCoverage.xsd ">
            <domainSubset>
                    <spatialSubset>
                            </gml:Envelope>
                                    <gml:limits>
                                            <gml:GridEnvelope>
                                            </gml:GridEnvelope>
                                    </gml:limits>
                            </gml:Grid>
                    </spatialSubset>
            </domainSubset>
            <rangeSubset>
                    </axisSubset>
            </rangeSubset>
            <output>
            </output>
    </GetCoverage>
    request?
    is unsupported.
    responses!
    Ed
    Universität Rostock
    18059 Rostock
    Join SourceForge.net's Techsay panel and you'll get the chance to
    share your
    <http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV&gt;
    <mailto:Geoserver-devel@lists.sourceforge.net>
    <https://lists.sourceforge.net/lists/listinfo/geoserver-devel&gt;
--------------------------------------------------------- !DSPAM:1003,45a7c1b2296551665516417!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Chris putting out a beta2 would be *great* from my standpoint; I would much rather perform an evaluation on a beta2 (then a war I produced on my own). I have enough fun with svn trying to get the OWS4 branch to go.
Jody
Chris
    Hi list,
            <domainSubset>
                    <spatialSubset>
                            </gml:Envelope>
                                    <gml:limits>
                                            <gml:GridEnvelope>
                                            </gml:GridEnvelope>
                                    </gml:limits>
                            </gml:Grid>
                    </spatialSubset>
            </domainSubset>
            <rangeSubset>
                    </axisSubset>
            </rangeSubset>
            <output>
            </output>
    </GetCoverage>
    request?
    is unsupported.
    responses!
    Ed
    Universität Rostock
    18059 Rostock
    share your
Hi Alessio,
thanks for the reply.
now I think your KVP request is wrong! According to the WCS spec, the coordinate order in the request is BBOX=minx, miny, maxx, maxy, minz, maxz (on p42 of the spec and p40 of the corrigendum). You've put them minx, maxx, miny, maxy (which to my mind makes more sense as well, particularly with optional z-values, but a spec is a spec!)
I just tried again and it seems to be working fine for me as well (on 1.5.0 beta 1). I can't replicate the failure, it maybe had something to do with another parameter as well.
Hi list,
        <domainSubset>
                <spatialSubset>
                        </gml:Envelope>
                                <gml:limits>
                                        <gml:GridEnvelope>
                                        </gml:GridEnvelope>
                                </gml:limits>
                        </gml:Grid>
                </spatialSubset>
        </domainSubset>
        <rangeSubset>
                </axisSubset>
        </rangeSubset>
        <output>
        </output>
</GetCoverage>
request?
is unsupported.
responses!
Ed
Hi Ed,
I don’t understand your reply … on my request (bbox=9.420000076293944,42.20000076293945,11.819999694824217,43.90000049273173) I’ve put minx,miny,maxx,maxy as for the WCS specs. Can you be more explicit?
On 1/15/07, Edward Nash <edward.nash@anonymised.com> wrote:
Hi Alessio,
maxz (on p42 of the spec and p40 of the corrigendum). You’ve put them
1.5.0 beta 1). I can’t replicate the failure, it maybe had something to
On 1/8/07, Edward Nash < edward.nash@anonymised.com> wrote:
Hi list,
nurc:Arc_Sample
gml:pos 11.819999694824217 43.90000049273173</gml:pos>
</gml:Envelope>
gml:limits
gml:GridEnvelope
</gml:GridEnvelope>
</gml:limits>
</gml:Grid>
1
EPSG:4326
EPSG:32626
GEOTIFF
request?
is unsupported.
responses!
Ed
Hi Alessio,
sorry for being a time-waster - I've just realised that your request is indeed right! (I blame specification-induced dyslexia).
I still don't understand why the very small (10x5 pixel) file is returned in response to the 'wrong' requestt though: surely the width & height requested should be respected even if it means sending back lots of "nothing" with just a bit of a few pixels of useful data somewhere in there.
Thanks again,
Ed
Hi Ed,
I don't understand your reply ... on my request (bbox=9.420000076293944,
42.20000076293945,11.819999694824217,43.90000049273173) I've put
Hi Alessio,
>> Hi list,
>> <domainSubset>
>> <spatialSubset>
</gml:pos>
>> </gml:Envelope>
>> <gml:limits>
>> <gml:GridEnvelope>
>> </gml:GridEnvelope>
>> </gml:limits>
>> </gml:Grid>
>> </spatialSubset>
>> </domainSubset>
>> <rangeSubset>
>> </axisSubset>
>> </rangeSubset>
>> <output>
>> </output>
>> </GetCoverage>
>> request?
if
>> is unsupported.
>> responses!
>> Cheers,
>> Ed
I don’t understand that too … on my version here I got an error if the bbox is wrong … however, GeoServer heavily depends on the below GeoTools jars … in most cases the GeoServer behaviour is different just because of the below libraries.
Anyway, as Jody said, I think that we could release a GeoServer 1.5.0-beta2 soon.
Hi Alessio,
sorry for being a time-waster - I’ve just realised that your request is
I still don’t understand why the very small (10x5 pixel) file is
returned in response to the ‘wrong’ requestt though: surely the width &
of “nothing” with just a bit of a few pixels of useful data somewhere in
there.
Thanks again,
Ed
Hi Ed,
I don’t understand your reply … on my request (bbox= 9.420000076293944,
On 1/15/07, Edward Nash < edward.nash@anonymised.com> wrote:
Hi Alessio,
on my
Hi list,
nurc:Arc_Sample
gml:pos 9.420000076293944
</gml:pos>
</gml:Envelope>
gml:limits
gml:GridEnvelope
</gml:GridEnvelope>
</gml:limits>
</gml:Grid>
1
EPSG:4326
EPSG:32626
GEOTIFF
request?
if
response_crs
is unsupported.
responses!
Ed
