[Geoserver-devel] WCS cite tests
Hi Alessio/developers
I ran WCS cite tests twice, the first time mixed in with the other configurations and the second time alone (just WCS cite configuration), and I am getting the same errors. I will be digging into the issue today to try and resolve it but I thought I would run it past you and the list first in case you had any ideas for a quick solution.
The error is the same for all the tests that failed:
Tue Feb 06 13:08:11 EST 2007 : Line = 1 Column = 2117 Message = {cvc-complex-type.3.1: Value 'urn:ogc:def:crs:OGC:1.3:CRS84' of attribute 'srsName' of element 'lonLatEnvelope' is not valid with repect to the corresponding attribute use.}
Brent Owens
(The Open Planning Project)
Oh,
it is a quite easy problem to solve then :slight_smile:
We have just to change urn:ogc:def:crs:OGC:1.3:CRS84 with the old WGS84(DD) in the GetCapabilities and DescribeCoverage.
{cvc-complex-type.3.1: Value ‘urn:ogc:def:crs:OGC:1.3:CRS84’ of
attribute ‘srsName’ of element ‘lonLatEnvelope’ is not valid with repect
Brent Owens
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
Hi Brent
Are you running cite tests under your own account? It would be helpful to me trying to work on getting all tests to pass on trunk if I could see the results of your rests runs on 1.5.x.
Do you think you could switch over to the geoserver account on the cite engine? Thanks.
-Justin
Justin Deoliveira
jdeolive@anonymised.com
http://topp.openplans.org
yeh sure thing. In the mean time I will give you my account name/password to look at the results I have right now. But I will run them on the public one next time around (in an hour or so).
Brent Owens
Justin Deoliveira wrote:
Hi Brent
-Justin
