Yes! This is exactly what I needed to know!
Seriously, I owe you a beverage of your choice.
Thanks a ton,
David Marks
From: Daniele Romagnoli <daniele.romagnoli@anonymised.com<mailto:daniele.romagnoli@anonymised.com>>
Date: Wednesday, June 10, 2015 at 3:22 AM
To: David Marks <david.marks@anonymised.com<mailto:david.marks@anonymised.com>>
Cc: Geoserver-devel <geoserver-devel@lists.sourceforge.net<mailto:geoserver-devel@lists.sourceforge.net>>
Subject: Re: [Geoserver-devel] WCS Custom Dimension AxisLabels
what do you mean with "valid axisLabel"?
Supposing you have a custom dimension named "WAVELENGTH", you can find it in the WCS2.0.1 describeCoverage response,
in the
<gmlcov:metadata>
<gmlcov:Extension>
<wcsgs:DimensionDomain name="WAVELENGTH" default="453">...
Therefore, you can send a GetCoverage request using that dimension in subsetting using slicing.
As an instance:
http://localhost:8080/geoserver/wcs?request=GetCoverage&service=WCS&version=2.0.1&coverageId=geosolutions__NO2&Format=image/tiff&subset=http://www.opengis.net/def/axis/OGC/0/Long(-116,-115.8)&subset=http://www.opengis.net/def/axis/OGC/0/Lat(32.5,32.9)&subset=WAVELENGTH(543)
Does it helps?
Please, let us know.
Daniele
On Mon, Jun 8, 2015 at 7:03 PM, Marks, David <David.Marks@anonymised.com<mailto:David.Marks@anonymised.com>> wrote:
Hello Geoserver-devel,
Hopefully easy question today, I'm publishing a number of layers with a custom dimension. Problem is, I can't figure out how to get the custom dimension to be set as a valid axisLabel so I can query using it with WCS 2.0.1. I assume it's something I need to do when publishing the layers, but I can't find info on when/how to do it. Any guidance would be appreciated!
David Marks
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@anonymised.comrge.net>
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
