[Geoserver-devel] WCS output formats
I have recently been adding functionality to geotools for it to support ENVI Hdr data files. I have managed to get the handler working, and the files are viewable with the WMS, and accessible through the WCS. Except:
When I run the following WCS query, I am returned a .eml file, instead of a geotiff:
http://localhost:8080/geoserver/wcs?service=WCS&request=GetCoverage&version=1.1.1&identifier=BlockAAlsmectiterelative&BoundingBox=235686.234,7880953.0,292701.234,7940609.5,urn:ogc:def:crs:EPSG::32754&format=image/geotiff
Also, I would like geoserver to return me ENVI Hdr BSQ files - possibly zipped. How would I go about adding functionality for a custom output format to geoserver?
I am using the latest geoserver 2.0 release.
Mat
Mathew Wyatt
Software Engineer, CSIRO Exploration and Mining
AARC (Australian Resources Research Centre)
26 Dick Perry Ave, Kensington WA 6151, Australia
Mathew Wyatt ha scritto:
Nice! Do you plan to contribute that back to the GeoTools community?
Getting a community module there is easy (and with some unit testing
and commitment it can become an official module too).
That is not a problem with output formats, it's the WCS spec that
_mandates_ one to return a mime/multipart response, the xml response
describing the outputs is the main document and the geotiffs
are attachments (sounds crazy, I know).
If you don't like that you have to use WCS 1.0 or use store=true
in WCS 1.1 and make two requests
Andrea Aime
OpenGeo - http://opengeo.org
Wow! Thanks for the speedy response Andrea.
Yes definitely, I'm happy to contribute it back. I pretty much copied the ESRI Hdr adapter and it seemed to work nicely.
of a geotiff:
Hmm... Yes I guess that does make sense is some crazy kind of way. Thanks for the options, I'll give them a go.
Mat
Andrea Aime
Mathew Wyatt
Hi Andrea,
Just for clarification. Is there any possibly way to have geoserver wcs return the 'nativeFormat' of the data in question? I have made a few attempts but had no success. Looking through the geoserver codebase it appears I need to write a 'CoverageResponseDelegate' for ENVIHdr files. Is this correct?
Mat
of a geotiff:
Andrea Aime
Mathew Wyatt
Hi Andrea,
Yep, that's the idea. The server will read your coverage from native format, slice, band select, reprject, and then use the delegate to
encode it back in the envi format.
The coverage formats have then to be registered in a class, can't remember its name right now, but if you search for the usage points
of the other delegates you'll find it.
I have a ticket open since quite a bit of time to make that pluggable,
should not be hard, it's just hard to find the time to do it :wink:
Andrea Aime
Ciao Matthew,
EnviHDR is not supported in write mode, or at least no yet, it would
be relatively easy to do that via imageio-ext.
Just for the records, could please detail a bit more about what you
have done geotools-wise to work with envi hdr?
Simone.
Ing. Simone Giannecchini
Founder - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Tue, Nov 24, 2009 at 4:03 AM, Mathew Wyatt <Mathew.Wyatt@anonymised.com> wrote:
Hi Andrea,
Mat
instead
of a geotiff:
Andrea Aime
Mathew Wyatt
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-devel mailing list
Hi Simone,
I have a large amount of remote sensing data in ENVIHdr BSQ format, that I would like to have delivered through a WCS. I have basically just copied what you have done for the ESRIHdr files in geotools and created an EnviHdrFormat etc. which utilizes the ENVIHdrImageReaderSpi from imageio-ext. This appears to have made my data readable through the WMS, WCS, as least from the small amount of testing I have done so far. What I would like to do now is have the ENVIHdr files delivered in their native format through the WCS.
From what you have said, this means that write mode functionality will have to be added to the imageio-ext libraries for ENVIHdr files before a CoverageResponseDelegate can be written. How long would you think it would take to add this sort of functionality to imageio-ext?
Mat
On 25/11/2009, at 8:10 AM, Simone Giannecchini wrote:
Ciao Matthew,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Andrea,
Mat
instead
of a geotiff:
Andrea Aime
Mathew Wyatt
Mathew Wyatt
Let's involve daniele who will be better than me in this discussion
since he is the main responsible for the imageio-ext framework.
Daniele, what is your feedback?
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Wed, Nov 25, 2009 at 3:34 AM, Mathew Wyatt <Mathew.Wyatt@anonymised.com> wrote:
Hi Simone,
Mat
Ciao Matthew,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Andrea,
Mat
instead
of a geotiff:
Andrea Aime
Mathew Wyatt
2008 30-Day
and focus on
Mathew Wyatt
Hi Mathew,
great to see that you have added support for EnviHdr at geotools level.
If you want to share with us your code we will take a look on it and we will include it in geotools.
About the ENVIHdr ImageWriter plugin, adding it to the imageio-ext plugins should be a feasible task in a short amount of time. If you wish to do it by yourself, I can surely provide you some guidance lines.
Let us know.
Best Regards,
Daniele
On Thu, Nov 26, 2009 at 12:21 AM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Let’s involve daniele who will be better than me in this discussion
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Wed, Nov 25, 2009 at 3:34 AM, Mathew Wyatt Mathew.Wyatt@anonymised.com wrote:
Hi Simone,
Mat
Ciao Matthew,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Andrea,
wcs return the ‘nativeFormat’ of the data in question? I have made a
codebase it appears I need to write a ‘CoverageResponseDelegate’ for
Mat
instead
of a geotiff:
That is not a problem with output formats, it’s the WCS spec that
mandates one to return a mime/multipart response, the xml response
If you don’t like that you have to use WCS 1.0 or use store=true
Andrea Aime
Mathew Wyatt
2008 30-Day
and focus on
what you do best, core application coding. Discover what’s new with
Mathew Wyatt
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
mob: +39 328 0559267
Hi Gabriel,
I would like to contribute the code for my ENVIHdr plugin. How do I go about this?
Also, any guidelines/hint/instructions you can provide on how to write an ImageWriter plugin would be fantastic!
Mat
________________________________________
From: dany.geotools@anonymised.com [dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli [daniele.romagnoli@anonymised.com]
Sent: Friday, 27 November 2009 7:55 PM
To: Simone Giannecchini
Cc: Wyatt, Mathew (E&M, Kensington); Geoserver-devel
Subject: Re: [Geoserver-devel] WCS output formats
Hi Mathew,
Let us know.
Best Regards,
Daniele
On Thu, Nov 26, 2009 at 12:21 AM, Simone Giannecchini <simone.giannecchini@...1268...<mailto:simone.giannecchini@anonymised.com>> wrote:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Simone,
Mat
Ciao Matthew,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Andrea,
Mat
instead
of a geotiff:
Andrea Aime
Mathew Wyatt
2008 30-Day
and focus on
Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@anonymised.comceforge.net>
Mathew Wyatt
Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@anonymised.comforge.net>
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi again Mathew,
sorry for the late reply.
please, read below…
On Sun, Feb 7, 2010 at 1:53 PM, Mathew.Wyatt@anonymised.com wrote:
Hi Gabriel,
You can open a JIRA against the geotools imageio-ext-gdal module and attach the patch needed to add your code. I will take a look on it.
In case you are talking about how to add writing capabilities to the ENVIHdr ImageIO-ext plugin, it is a very easy task, being the real writing code already contained in the gdalframework’s base classes. The only things you need to do, is defining some format specific classes and do some tuning on them depending on the capabilities offered by the ENVIHdr driver. In order to do this, you can start by looking on the imageio-ext source code. To be more specific, you can refer to the gdalgeotiff or the gdalkakadujp2 imageio-ext plugins since they also provide writing capabilities. Moreover, you can get some additional info, by taking a look on chapter 4 of the ImageI/O-Ext user guide 1.
Hope this helps.
Daniele
Mat
Hi Mathew,
Let us know.
Best Regards,
Daniele
On Thu, Nov 26, 2009 at 12:21 AM, Simone Giannecchini <simone.giannecchini@anonymised.commailto:[simone.giannecchini@anonymised.com](mailto:simone.giannecchini@anonymised.com)> wrote:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Simone,
Mat
Ciao Matthew,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Andrea,
Mat
instead
of a geotiff:
Andrea Aime
Mathew Wyatt
2008 30-Day
and focus on
Geoserver-devel@lists.sourceforge.netmailto:[Geoserver-devel@anonymised.comnet](mailto:Geoserver-devel@lists.sourceforge.net)
Mathew Wyatt
Geoserver-devel@lists.sourceforge.netmailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
No worries Daniele, I have been pre-occupied with other things myself. I have put the patch into Jira - http://jira.codehaus.org/browse/GEOT-2971
Thank you for the information on adding write functionality. I'm pleased to hear that it shouldn't be too much work.
Mat
Sent: Monday, 15 February 2010 10:10 PM
To: Wyatt, Mathew (CESRE, Kensington)
Cc: geoserver-devel@lists.sourceforge.net
Hi again Mathew,
please, read below...
On Sun, Feb 7, 2010 at 1:53 PM, <Mathew.Wyatt@anonymised.com> wrote:
Hi Gabriel,
In case you are talking about how to add writing capabilities to the ENVIHdr ImageIO-ext plugin, it is a very easy task, being the real writing code already contained in the gdalframework's base classes. The only things you need to do, is defining some format specific classes and do some tuning on them depending on the capabilities offered by the ENVIHdr driver. In order to do this, you can start by looking on the imageio-ext source code. To be more specific, you can refer to the gdalgeotiff or the gdalkakadujp2 imageio-ext plugins since they also provide writing capabilities. Moreover, you can get some additional info, by taking a look on chapter 4 of the ImageI/O-Ext user guide [1].
Hope this helps.
Daniele
[1]: https://imageio-ext.dev.java.net/files/documents/7505/124117/ImageioExt-UserGuide.pdf
Mat
From: dany.geotools@anonymised.com<mailto:dany.geotools@anonymised.com> [dany.geotools@anonymised.com<mailto:dany.geotools@anonymised.com>] On Behalf Of Daniele Romagnoli [daniele.romagnoli@anonymised.com<mailto:daniele.romagnoli@anonymised.com>]
Hi Mathew,
Let us know.
Best Regards,
Daniele
On Thu, Nov 26, 2009 at 12:21 AM, Simone Giannecchini <simone.giannecchini@...1268...<mailto:simone.giannecchini@anonymised.com><mailto:simone.giannecchini@anonymised.com>> wrote:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Simone,
Mat
Ciao Matthew,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Andrea,
Mat
instead
of a geotiff:
Andrea Aime
Mathew Wyatt
2008 30-Day
and focus on
Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@anonymised.comceforge.net><mailto:Geoserver-devel@lists.sourceforge.net>
Mathew Wyatt
Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@anonymised.comforge.net><mailto:Geoserver-devel@lists.sourceforge.net>
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Mathew,
I have updated the JIRA with some additional info. Thank you for adding this new format to GeoTools.
In such a context, I have some brief notes and feedbacks on the patch you provided:
  • Please, never use a System.out.println in the code; use the logger instead if you need to track something.
  • When doing a “svn diff” or similar commands to create a patch, make sure that experimental/debugging code lines doesn’t go in the patch. (As an instance, I have noticed that there are changes on modules/library/sample-data/src/main/java/org/geotools/test/TestData.java containing System.out.println calls.)
  • Finally, instead of hardcoding the imageio-ext version within the imageio-ext-gdal plugin module’s pom, it is preferred to add a dependency with only artifact-id and group-id; then, make sure to specify the version in the main geotools pom, within the dependencyManagement section (note that we specify that version by referring to an imageio.ext.version property to avoid specifying in each tag the required version). By this way, when moving to a new imageio-ext version, we only need to update the imageio.ext.version property in the root’s pom without touching any other poms/xml-tags .
I would like to point out that my feedbacks should be taken as constructive instead of hostile criticism :slight_smile:
I will update the geootols code with the new format, today.
Best Regards,
Daniele
Thank you for the information on adding write functionality. I’m pleased to hear that it shouldn’t be too much work.
Mat
Hi again Mathew,
please, read below…
Hi Gabriel,
Hope this helps.
Daniele
Mat
From: dany.geotools@anonymised.com…mailto:[dany.geotools@...403...](mailto:dany.geotools@anonymised.com) [dany.geotools@anonymised.commailto:[dany.geotools@anonymised.com](mailto:dany.geotools@anonymised.com)] On Behalf Of Daniele Romagnoli [daniele.romagnoli@anonymised.commailto:[daniele.romagnoli@anonymised.com](mailto:daniele.romagnoli@anonymised.com)]
Hi Mathew,
Let us know.
Best Regards,
Daniele
On Thu, Nov 26, 2009 at 12:21 AM, Simone Giannecchini <simone.giannecchini@anonymised.commailto:[simone.giannecchini@anonymised.com](mailto:simone.giannecchini@anonymised.com)<mailto:simone.giannecchini@anonymised.commailto:[simone.giannecchini@anonymised.com](mailto:simone.giannecchini@anonymised.com)>> wrote:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Simone,
Mat
Ciao Matthew,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Andrea,
Mat
instead
of a geotiff:
Andrea Aime
Mathew Wyatt
2008 30-Day
and focus on
Geoserver-devel@lists.sourceforge.netmailto:[Geoserver-devel@anonymised.comnet](mailto:Geoserver-devel@lists.sourceforge.net)<mailto:Geoserver-devel@lists.sourceforge.netmailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)>
Mathew Wyatt
Geoserver-devel@lists.sourceforge.netmailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)<mailto:Geoserver-devel@lists.sourceforge.netmailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)>
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Daniele,
I'm embarrassed to have left those System.out statements in :expressionless: (slaps on the wrist)
I take you point regarding artifact versioning. Will remember for future reference. No offence taken on the feedback :slight_smile:
Mat
Sent: Wednesday, 10 March 2010 8:18 PM
Hi Mathew,
- Please, never use a System.out.println in the code; use the logger instead if you need to track something.
- When doing a "svn diff" or similar commands to create a patch, make sure that experimental/debugging code lines doesn't go in the patch. (As an instance, I have noticed that there are changes on modules/library/sample-data/src/main/java/org/geotools/test/TestData.java containing System.out.println calls.)
- Finally, instead of hardcoding the imageio-ext version within the imageio-ext-gdal plugin module's pom, it is preferred to add a dependency with only artifact-id and group-id; then, make sure to specify the version in the main geotools pom, within the dependencyManagement section (note that we specify that version by referring to an imageio.ext.version property to avoid specifying in each tag the required version). By this way, when moving to a new imageio-ext version, we only need to update the imageio.ext.version property in the root's pom without touching any other poms/xml-tags .
Best Regards,
Daniele
Mat
Cc: geoserver-devel@lists.sourceforge.net<mailto:geoserver-devel@anonymised.comceforge.net>
Hi again Mathew,
Hi Gabriel,
Hope this helps.
Daniele
Mat
From: dany.geotools@anonymised.com<mailto:dany.geotools@anonymised.com><mailto:dany.geotools@anonymised.com> [dany.geotools@anonymised.com<mailto:dany.geotools@anonymised.com><mailto:dany.geotools@anonymised.com>] On Behalf Of Daniele Romagnoli [daniele.romagnoli@anonymised.com.1268...<mailto:daniele.romagnoli@anonymised.com><mailto:daniele.romagnoli@anonymised.com268...<mailto:daniele.romagnoli@anonymised.com>>]
Hi Mathew,
Let us know.
Best Regards,
Daniele
On Thu, Nov 26, 2009 at 12:21 AM, Simone Giannecchini <simone.giannecchini@...1268...<mailto:simone.giannecchini@anonymised.com><mailto:simone.giannecchini@anonymised.com><mailto:simone.giannecchini@anonymised.com<mailto:simone.giannecchini@anonymised.com>>> wrote:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Simone,
Mat
Ciao Matthew,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Andrea,
Mat
instead
of a geotiff:
Andrea Aime
Mathew Wyatt
2008 30-Day
and focus on
Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@anonymised.comceforge.net><mailto:Geoserver-devel@lists.sourceforge.net><mailto:Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@anonymised.comsourceforge.net<mailto:Geoserver-devel@lists.sourceforge.net>>>
Mathew Wyatt
Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@anonymised.comforge.net><mailto:Geoserver-devel@lists.sourceforge.net><mailto:Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@anonymised.comurceforge.net<mailto:Geoserver-devel@lists.sourceforge.net>>>
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
