[Geoserver-devel] wcs schema and cite tests
I am running WCS 1.0 cite tests and have come across something odd. The element "lonLatEnvelope" declares a srsName attribute, which if you look at the schema should be fixed as "urn:ogc:def:crs:OGC:1.3:CRS84". Looking at an old version of the schema it seems to be fixed to "WGS84(DD)".
When running the engine, the engine will fail if the former is used. So could the engine be still using the old schema to validate?
-Justin
Justin Deoliveira
jdeolive@anonymised.com
The Open Planning Project
http://topp.openplans.org
I wouldn't be surprised if they slipped on it and forgot to change to the new version of the schema.
I had to change it to "WGS84(DD)" in order to pass cite tests, although it feels as though it should be "urn:ogc:def:crs:OGC:1.3:CRS84"
Brent Owens
(The Open Planning Project)
Justin Deoliveira wrote:
-Justin
