GeoServer Developers:
In GeoServer version 1.7, are the WCS TIME & ELEVATION parameters going to be supported as indicated by GSIP 24?
If yes, do you have any sample code for a GeoTools coverage plug-in that uses the WCS TIME & ELEVATION parameters? I have checked out version 1.7-RC3 and have inspected some of the code for the EMF bindings, but I could not find an example of a plug-in that uses the EMF bindings–not that I have any real experience with EMF bindings.
My objective is to develop is to develop a GeoTools coverage plug-in for a proprietary data format where there are 2D coverages that vary in time and elevation, and I would like to only register one coverage store and coverage per data parameter using time and elevation to select the individual 2D coverages.
Thank you,
Alan Smith
