[Geoserver-devel] Wcs
Hello, i am beginner with Geoserver and OGIS (and my english also, sorry for that). I have read some informations around WCS. I want to know if a version of Geoserver with WCS is available now?
Thanks.
Ricaille Tanguy.
You can find some early versions of GeoServer WCS Experiment on sourceforge with an easy installer.
Otherwise you can get the last (under development) release on the Subversion CVS repository here
https://svn.codehaus.org/geoserver/branches/wcs-branch/trunk/geoserver
which is aligned with the GeoTools 2.2.x Coverage Branch libraries here
http://svn.geotools.org/geotools/branches/coverages_branch/trunk
and GeoServer 1.3.0 here
https://svn.codehaus.org/geoserver/trunk/geoserver
Thanks.
Ricaille Tanguy.
Thanks, i’m also looking about security on data: is it possible to limit access of data depending on user type or name or anything else? Through Geoserver, Geotools or PostGIS ?
----- Original Message -----
To: Ricaille Tanguy
Cc: geoserver-devel@anonymised.comts.sourceforge.net
Sent: Tuesday, January 31, 2006 11:18 AM
Subject: Re: [Geoserver-devel] Wcs
Thanks.
Ricaille Tanguy.
Ricaille Tanguy wrote:
Thanks, i'm also looking about security on data: is it possible to limit access of data depending on user type or name or anything else? Through Geoserver, Geotools or PostGIS ?
Actually through DACS (distrubuted access control system I think). We have used this with MapServer and GeoServer and uDig with some sucesss.
- http://dacs.dss.ca/
- Open Web Services, Phase 3 : Home
There are ways in place to let you pass in credentials to the WFS and limit things at the attribute level as well, but nobody has done this for geosever yet.
