However it is not getting deployed to sourceforge and linked
from the download page.
Shall we rectifiy it?
Wondering about the download pages, it seems they are using
some sort of templating system, so if we change the template,
this will affect all previous releases too?
Besides the pdf issue, I guess the template will break the moment
we add a new extension, are there ways to use the templates only
for certain ranges of downloads?
GeoServer Professional Services from the experts! Visit http://goo.gl/NWWaa2 for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Yes if we change the template previous pages are instantly modified. A couple months ago I moved the extensions around for previous releases to avoid broken links.
Ing. Andrea Aime
@geowolf
Technical Lead
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world’s largest code
search on Ohloh, the Black Duck Open Hub! Try it now. http://p.sf.net/sfu/bds
On Mon, Jul 28, 2014 at 12:53 AM, Jody Garnett <jody.garnett@anonymised.com>
avoid broken links.
Well, eventually we'll need a way to have a new extension be added only to
the releases that
do contain it.
Is it possible to have alternate templates?
Ing. Andrea Aime @geowolf
Technical Lead
It is possible to use a different template but it would mean a lot of duplication.
The template language [1] supports conditionals and may other constructs so I would just add a conditional around the adding of any new elements to the page. Every release page declares its version so I would use that as the input. To do it cleanly I guess we would probably need a custom filter to compare versions. Adding such things is pretty straight forward [2]. Jody is a rubyist, so it should be easy for him to add a new version compare filter
Well, eventually we’ll need a way to have a new extension be added only to the releases that
do contain it.
Ing. Andrea Aime
@geowolf
Technical Lead
I have made two release templates thus far, one for the releases and one for the nightlies.
I was not aware you could do conditionals, for the home page and download page I have being hiding elements in javascript as per justin’s example. So if there is no dev_release the beta download won’t be shown and we will end up with just a link to the nightly.
I have wasted a bit too much time ironing out the website glitches and would like to see a few more devs get comfortable with it
do contain it.
Ing. Andrea Aime
@geowolf
Technical Lead
