[Geoserver-devel] we are mixing slf4j versions in jetty
I was trying to use the bin package of geoserver which ships a standalone version of jetty but in some cases I’m getting:
java.lang.NoSuchMethodError: org.slf4j.Logger.isTraceEnabled()Z
which comes from my plugin.
In geoserver we never call this method (isTraceEnabled()) which was added after the 1.4 (http://www.slf4j.org/api/org/slf4j/Logger.html#isTraceEnabled%28%29)
so the problem never throws up.
The wrong library version comes from the jetty package and is located here:
./geoserver-2.4-SNAPSHOT/lib/slf4j-simple-1.0.1.jar
It should be 1.5.8 instead.
Anyhow I think we can just remove it since we are also shipping the slf4j-api, slf4j-log4j12 and the log4j implementation 1.2.14 which is sufficient.
What do you think?
Carlo
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK for more information.
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
Ciao Carlo,
I would suggest to just remove this lib if it is not needed for the
bin GeoServer
I would probably does it first on Master and then backport after 1 month.
I don't think this requires a GSIP, prepare a pull request for people to test.
Sooner rather than later I would probably upgrade our Jetty dependency as well.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Tue, Apr 8, 2014 at 6:16 PM, carlo cancellieri
<carlo.cancellieri@anonymised.com> wrote:
version of jetty but in some cases I'm getting:
after the 1.4
(http://www.slf4j.org/api/org/slf4j/Logger.html#isTraceEnabled())
sufficient.
What do you think?
Carlo
information.
@cancellieric
Software Engineer
On Wed, Apr 9, 2014 at 11:06 AM, Simone Giannecchini <
simone.giannecchini@anonymised.com> wrote:
Ciao Carlo,
bin GeoServer
test.
well.
There was a discussion recently, in order to upgrade Jetty we need to first
use
Java 7 as the minimum, as Jetty started requiring it a long time ago.
Another option would be to look if we can use a stripped down tomcat
instead.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
On Tue, Apr 8, 2014 at 6:16 PM, carlo cancellieri <
after the 1.4 (
here:
sufficient.
What do you think?
That we need to check if Jetty is using the library for its own logging,
and if so, if we can replace the one in the shared libs
with a newer one without causing troubles to Jetty
Ing. Andrea Aime
@geowolf
Technical Lead
Here is the pull req (description is attached):
https://github.com/geoserver/geoserver/pull/558
2014-04-09 14:49 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
@cancellieric
Software Engineer
On Tue, Apr 8, 2014 at 6:16 PM, carlo cancellieri <carlo.cancellieri@anonymised.com> wrote:
What do you think?
That we need to check if Jetty is using the library for its own logging, and if so, if we can replace the one in the shared libs
Ing. Andrea Aime
@geowolf
Technical Lead
Ciao Andrea,
clarification:
  • apparently jetty does not use this lib
  • we removed it and tested it the geoserver binaries and things worked
The pull request simply removes that dependency form building the bin so that others can test.
Simone Giannecchini
@simogeo
Founder/Director
On Wed, Apr 9, 2014 at 4:19 PM, carlo cancellieri <carlo.cancellieri@anonymised.com> wrote:
Put Bad Developers to Shame
Dominate Development with Jenkins Continuous Integration
Continuously Automate Build, Test & Deployment
Start a new project now. Try Jenkins in the cloud.
http://p.sf.net/sfu/13600_Cloudbees
Geoserver-devel mailing list
@cancellieric
Software Engineer
What do you think?
Ing. Andrea Aime
@geowolf
Technical Lead
Here is the related jira
https://jira.codehaus.org/browse/GEOS-6444
Carlo
2014-04-09 16:52 GMT+02:00 Simone Giannecchini <simone.giannecchini@anonymised.com>:
Ciao Andrea,
clarification:
@cancellieric
Software Engineer
Simone Giannecchini
@simogeo
Founder/Director
@cancellieric
Software Engineer
What do you think?
Ing. Andrea Aime
@geowolf
Technical Lead
