Hi Jonathan,
I’m actually wondering if the search ever worked, I remember similar issues years ago.
I normally use Google to search for GeoServer docs.
If someone could spare time to investigate why it’s not working/what we’re missing and fix it,
it would be much appreciated of course
On Sat, Jun 16, 2018 at 12:20 AM, Jonathan Moules <jonathan-lists@anonymised.com> wrote:
Hi Folks,
The website search isn’t currently working. The links all seem to have an extraneous “.rst” in the url.
i.e.:
http://docs.geoserver.org/latest/en/user/search.html?check_keywords=yes&area=default&q=password&x=0&y=0
has links to pages like:
http://docs.geoserver.org/latest/en/user/security/index.rst.html?highlight=password
when it should be:
http://docs.geoserver.org/latest/en/user/security/index.html?highlight=password
Jonathan
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea,
Well, I guess the server keeps logs as to how often it’s used. It definitely worked last time I used it (quite a while back mind), though I agree that (as I believe I have lamented before) it’s not the most efficacious search engine.
I tried taking a look through the code but can’t seem to find it. I expect the string “activate JavaScript to enable the” to be in the search code, but there are no hits for that at all in https://github.com/geoserver
Jonathan
On 2018-06-16 09:13, Andrea Aime wrote:
Hi Jonathan,
Hi Folks,
i.e.:
when it should be:
Jonathan
Geoserver-devel@anonymised.com.756…rge.net
