Hey,
as you might know, the ArcSDE raster support is now based on JAI, like in using a custom ImageInputStream to read from a SDE raster query stream. For background: this ImageInputStream backs a RawImageInputStream.
So the resulting RenderedImage for an ArcSDE coverage request is a small JAI ops chain like read->crop->scale->translate->mosaic (forget about the mosaic part when the arcsde raster is not a raster catalog -i.e., a runtime generated mosaic-)
Everything works well as long as deferred loading of tiles is not used. To force that, I must call RenderedImage.getData() before returning the image resulting from the read operation. That is a tiled one matching the ArcSDE raster tile dimension.
But if I don´t do so, strange artifacts appear in the WMS GetMap responses. Some seem to be avoided if I forcedly disable MetaTiling, like in commenting out the following code at GetMapReponse line 165:
//if (MetatileMapProducer.isRequestTiled(request, delegate)) {...
but others persist.
Artifacts are either tiles with repeating patterns (like in a single tile being repeated) or images with blank rectangles.
I suspected of the ESRI api's thread safety wrt internal tile buffers or something, but that might happen even for non tiling requests.
So, (and apologies for the long preface), question is, does someone already experienced this kind of problems with JAI and deferred loading? Any known work around or thing to have in mind to get it working properly?
I know it's hard to answer with such a vague description but if you ever experienced something similar please let me know.
Gabriel
Gabriel Roldan
OpenGeo - http://opengeo.org
Hey,
wrt the repeated tiles when metatiling is enabled, I found it only happens if the output format is JPEG, PNG and GIS are ok.
The attached images show how tiling requests look when metatiling is activated or not, and output format is jpeg.
any idea?
Gabriel
Gabriel Roldan wrote:
Hey,
but others persist.
Gabriel
Gabriel Roldan
(attachments)
>and GIS are ok.
I mean GIF
I've had this same problem in GWC[1], it's been around for 2 years ++, never understood how it could work in GeoServer, but then again I'm not sure I ever configured a tiled=true client correctly either. (In my code useJAI is set to false if it's JPEG)
-Arne
1: http://geowebcache.org/trac/browser/trunk/geowebcache/src/main/java/org/geowebcache/layer/wms/WMSMetaTile.java#L223
Hey,
any idea?
Gabriel
Hey,
but others persist.
Gabriel
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
Geoserver-devel mailing list
Arne Kepp
Hey Arne, that´s good to know... so it´s not me getting crazy, but a known issue.
May be Simone or Daniele know something about that?
Gabriel
-Arne
Hey,
any idea?
Gabriel
Hey,
but others persist.
Gabriel
Gabriel Roldan
Hi Gabriel,
sorry but I don’t remember a similar issue before. (But my memory could fail…)
Simone could have more info about this but actually he is away for vacation.
Daniele
On Wed, Oct 28, 2009 at 9:18 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Hey Arne, that´s good to know… so it´s not me getting crazy, but a known issue.
Gabriel
Arne Kepp wrote:
I’ve had this same problem in GWC[1], it’s been around for 2 years ++, never understood how it could work in GeoServer, but then again I’m not sure I ever configured a tiled=true client correctly either. (In my code useJAI is set to false if it’s JPEG)
-Arne
Hey,
any idea?
Gabriel
Hey,
//if (MetatileMapProducer.isRequestTiled(request, delegate)) {…
but others persist.
I suspected of the ESRI api’s thread safety wrt internal tile buffers or something, but that might happen even for non tiling requests.
I know it’s hard to answer with such a vague description but if you ever experienced something similar please let me know.
Gabriel
Gabriel Roldan
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
Hi Arne,
Looks like the same workaround needs to be done in GeoServer, this time in JPEGMapProducer. Patch for GeoServer at <http://jira.codehaus.org/browse/GEOS-3612>\.
-Arne
Hey,
any idea?
Gabriel
Hey,
but others persist.
Gabriel
Gabriel Roldan
Cool, so just make sure I got this right, and we're describing the same thing:
This is not a bug in JAI itself, rather it is a bug that occurs when using the JAI wrapper and native JAI is not available?
(I usually don't have JAI installed in my dev environment, partially because I know that most devs *do*)
-Arne
Hi Arne,
-Arne
Hey,
any idea?
Gabriel
Hey,
but others persist.
Gabriel
Arne Kepp
Gabriel Roldan ha scritto:
Hi Arne,
sorry for the late answer, I'm supposed to be in vacation and I was
not actually reading the mails that ended up in OpenGeo related
folders (since massgis-devel was cc'ed the mail ended up in one of
such folders).
Someone reported me a very similar issue during FOSS4G and I did open
a bug report, http://jira.codehaus.org/browse/GEOS-3592, managed to
talk a little with Simone about it but we did not have time to look into it.
The issue is occurring only if one has the native JPEG acceleration enabled but the native JAI libraries are not there. The patch you're
proposing is probably going to slow down image serving in the case
the JAI Image I/O extensions are actually installed (I need to double
check but I believe the bug is not showing itself if you either
disable native jpeg acceleration in the GS config or if you properly
install the native JPEG acceleration libraries)
Hi Arne,
such folders).
no worries, thanks for replying. I am supposed to be on vacation too, just kept on following this issue as it prevented me to finish out the project last week.
That makes sense I think, as I'm running on Mac I don't have native image-io at all, only JAI.
I am aware the patch might slow down things hence the request for support. I am pretty sure the bug shows itself anyways, at least in my case.
let's follow up on it when we're all back from vacation.
Gabriel
Gabriel Roldan
Just to confirm,
do you need any help for GEOS-3612 and GEOS-3592, my understanding is
that you do not?
Simone.
Ing. Simone Giannecchini
Founder - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
Hi Arne,
such folders).
Hi Simone,
thanks for asking. Please read bellow.
Simone Giannecchini wrote:
Just to confirm,
that you do not?
I actually do.
My understanding of the problem is as follows:
- this happens only on trunk (2.0.x too I assume), but not on 1.7.x
- problem is the JPEG writer, or rather the ImageWorker.writeJPEG, does not respect the image location and always writes the image starting at 0,0
- this shows up when doing a tiling request, since the metatile creates each tile as a subset of the metatile image. Hence the tiles being RenderedImages with x,y origin not at 0,0 suffer from this
- The following block of code in JPEGMapProducer does not seem to be causing any effect:
if (! jpegNativeAcc&&image.getMinX()!=0 || image.getMinY()!=0) {
// I don't make an expliciti copy anymore, hoping that sooner or later:
// A> this bug will be fixed
// B> JDK JpegImageWriter will stop making a straight copy of the input raster
mage= TranslateDescriptor.create(image, new Float(-image.getMinX()), new Float(-image.getMinY()), new InterpolationNearest(), null);
the JPEG writer keeps on writing the tile starting at 0,0 of the backing image (the metatile one).
So any advice on how to better work around this, if possible, than the patch I've attached to GEOS-3612 would be very much welcomed, as that is expected to be imposing some performance penalty, though I didn't measure it.
Gabriel
Problem should have been fixed on trunk and 2.0.x.
Please, test.
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Tue, Nov 10, 2009 at 7:00 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Hi Simone,
Just to confirm,
that you do not?
I actually do.
any effect:
raster
Gabriel
Archive: http://lists.opengeo.org/massgis-dev/archive/2009/11/1257879627043
To unsubscribe send an email with subject "unsubscribe" to
massgis-devel@anonymised.com Please contact
massgis-devel-manager@anonymised.com for questions.
