[Geoserver-devel] WFS 1.1.0 and WFS 2.0 Schemas and Complex Features
This is about this issue: https://osgeo-org.atlassian.net/browse/GEOS-8108
The referenced mailing list discussion is about being able to have multiple workspaces with the same name space, this is another issue.
The issue here is that when creating a XML schema for complex features in the context of a virtual service only the feature types belonging to that feature type will be used, hence chained features of other workspaces will have a NULL prefix:
A possible solution for this is to iterate over all complex type properties and extract the chained feature types and add them to the schema. This raise several technical questions that need to be investigated:
  • is it actually possible to find the chained features of a complex feature by simply looking at is properties ? I think so based on the property name or at least we can find the associated workspace and use all the features of that workspace.
  • what is the best way to access other workspaces elements in the context of a virtual service ? The raw catalog ?
  • allowing feature types of a another workspace to be use in the context of another workspace virtual service is acceptable ? The user will be awre of this when setting up the security rules but apart from that I guess this is fine.
This fix will need to be made in WFS 1.1.0 and WFS 2.0. Currently I don’t think app-schema as a test case with a complex feature that chain features of another workspace, so a test case will need to be created by this (I guess the stations use case can be extend for this).
Opinions ?
Nuno Oliveira
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
55054  Massarosa (LU)
fax:   +39 0584 1660272
mob:   +39  333 8128928
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
