[Geoserver-devel] wfs 1.1 cite test issues
A summary of where we stand on cite issues for wfs 1.1. Most of the failures found by victor were a result of the EntityGeneric layer and svn encoding issues. Basically when I checked it out on the server it somehow ended up with a non UTF encoding so comparisons with other UTF versions of the strings were failing. @Ben: I thought you had a way around this at some point?
Anyways, other then that there were two legit failures. Actually these were new cite tests recently added that require GML2 requests to return a mime type with the subtype included, rather than just text/xml. Easy fix.
Other then that there are still some issues that are "failing" but I don't consider blockers. They are explained below:
* wfs:wfs-1.1.0-Basic-GetFeature-tc42.4
fails on postgres versions 8.3 or greater. Been an open issue for quite some time.
* wfs:wfs-1.1.0-Basic-GetFeature-tc200.2
I was surprised buy this one. THe issue is that GEoServer complains about a validation failure with the following request:
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:gml="http://www.opengis.net/gml&quot;&gt;
       <ogc:BBOX>
           <gml:Envelope srsName="urn:x-ogc:def:crs:EPSG:4326">
             <gml:lowerCorner>34 14</gml:lowerCorner>
             <gml:upperCorner>41 23</gml:upperCorner>
           </gml:Envelope>
       </ogc:BBOX>
     </ogc:Filter>
I could have sworn that the wfs and filter specs allowed one to leave off the PropertyName in a BBOX filter. But if i look at the filter schema [1] under BBOXType I indeed see that PropertyName is not optional.
So it would appear the test is in error here. Patching to include PropertyName it works fine.
* wfs:Transaction-idgen-use-existing
* wfs:Transaction-idgen-use-existing-update
These two tests require that the server accept feature ids from the client which we don't support. I have brought this up on the cite list but have gotten no feedback. But I argue strongly against a WFS supporting this even though there is a plan to implement this in GeoServer regardless.
If it is to be supported it has to be something that is settable on a feature type by feature type basis imo.
Also these tests were added sometime recently and not really cleared with any of the implementers afaik. If it was it was not made public.
So I don't think these should be considered blockers.
-Justin
[1] http://schemas.opengis.net/filter/1.1.0/filter.xsd
Justin Deoliveira
OpenGeo - http://opengeo.org
That sounds really great, thank you so much Justin :slight_smile:
I can see the update on the 2.0.2 tag so I am going to do one last build and
test and hopefully get 2.0.2 released today.
If anyone has any objection now is the time to say or hold your silence
forever :stuck_out_tongue:
fix.
some time.
       <ogc:BBOX>
           </gml:Envelope>
       </ogc:BBOX>
     </ogc:Filter>
-Justin
Justin Deoliveira
Geoserver-devel mailing list
View this message in context: http://old.nabble.com/wfs-1.1-cite-test-issues-tp28615908p28616455.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Well actually it seems there are some minor issues with wcs 1.0.0 cite tests as well :frowning:
I think i am done working through the issues. I will send email and commit soon.
-Justin
fix.
some time.
        <ogc:BBOX>
            </gml:Envelope>
        </ogc:BBOX>
      </ogc:Filter>
-Justin
Justin Deoliveira
Justin Deoliveira
My wcs1.0 passed when I was testing it. But I am doing a full rebuild now and
I will run all test cases again :slight_smile:
commit soon.
-Justin
and
fix.
some time.
        <ogc:BBOX>
            </gml:Envelope>
        </ogc:BBOX>
      </ogc:Filter>
optional.
-Justin
Justin Deoliveira
Justin Deoliveira
View this message in context: http://old.nabble.com/wfs-1.1-cite-test-issues-tp28615908p28616643.html
We may have a version conflict with the tests... are you running hte trunk version of the wcs tests from svn? Or an older one that was posted?
commit soon.
-Justin
and
fix.
some time.
         <ogc:BBOX>
             </gml:Envelope>
         </ogc:BBOX>
       </ogc:Filter>
optional.
-Justin
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
