[Geoserver-devel] WFS 2.0.0 and GML 3.1.1
Is there a known issue with combining WFS 2.0.0 and GML 3.1.1? As far as I can tell, there isn’t any reason this would be an unsupported combination. Testing on all currently available versions of GeoServer (2.5.4, 2.6.2, and 2.7beta) yield the same exception:
<ows:ExceptionReport xmlns:ows=“http://www.opengis.net/ows/1.1” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” version=“2.0.0” xsi:schemaLocation=“http://www.opengis.net/ows/1.1 http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd”>
<ows:Exception exceptionCode=“NoApplicableCode”>
ows:ExceptionText
java.lang.RuntimeException: Failed to get property: {http://www.opengis.net/gml}featureMembers Failed to get property: {http://www.opengis.net/gml}featureMembers net.opengis.wfs20.impl.FeatureCollectionTypeImpl cannot be cast to net.opengis.wfs.FeatureCollectionType
</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
For reference I was making a GetFeature request with the following query:
http://localhost:8080/geoserver/topp/ows?service=WFS&version=2.0.0&request=GetFeature&typeName=topp:tasmania_cities&count=50&outputFormat=text/xml;%20subtype=gml/3.1.1
I also tried the query against WFS and global OWS service, as opposed to the virtual topp OWS.
v/r,
Jonathan Meyer
Applied Information Sciences
I was already aware of this bug and I just checked and there is already a jira issue as well. Something that indeed should be solved.
Regards
Niels
On 03-02-15 05:44, Jonathan Meyer wrote:
Is there a known issue with combining WFS 2.0.0 and GML 3.1.1? As far as I can tell, there isn't any reason this would be an unsupported combination. Testing on all currently available versions of GeoServer (2.5.4, 2.6.2, and 2.7beta) yield the same exception:
<ows:ExceptionReportxmlns:ows="http://www.opengis.net/ows/1.1&quot;xmlns:xsi=&quot;http://www.w3.org/2001/XMLSchema-instance&quot;version=&quot;2\.0\.0&quot;xsi:schemaLocation=&quot;http://www.opengis.net/ows/1.1 http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd&quot;&gt;
<ows:ExceptionexceptionCode="NoApplicableCode">
<ows:ExceptionText>
java.lang.RuntimeException: Failed to get property: {http://www.opengis.net/gml\}featureMembers <http://www.opengis.net/gml}featureMembers&gt; Failed to get property: {http://www.opengis.net/gml\}featureMembers <http://www.opengis.net/gml}featureMembers&gt; net.opengis.wfs20.impl.FeatureCollectionTypeImpl cannot be cast to net.opengis.wfs.FeatureCollectionType
</ows:Exception>
v/r,
Jonathan Meyer
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
Geoserver-devel mailing list
Yeah, we also have the opposite case, GML 3.2 not working correctly with
WFS 1.0 (but being advertised as a supported format in that protocol too)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1&quot; xmlns:xsi
="http://www.w3.org/2001/XMLSchema-instance&quot; version="2.0.0"
xsi:schemaLocation="http://www.opengis.net/ows/1.1
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>
http://www.opengis.net/gml\}featureMembers Failed to get property: {
</ows:Exception>
Should be fixed for 2.7.x, 2.6.x and 2.5.x:
http://jira.codehaus.org/browse/GEOS-6134
Kudos to koordinates.com for sponsoring the fix
Ing. Andrea Aime
@geowolf
Technical Lead
