For KVP-encoded ad hoc query expressions the typeNames parameter shall be encoded using the TYPENAMES keyword (see Table 8). The TYPENAMES parameter is mandatory in all cases except when the RESOURCEID parameter is specified. In this case the TYPENAMES parameter may be omitted because each feature instance can be identified by its resource identifier alone (see 7.2). If both the TYPENAMES and RESOURCEID parameters are specified then all the feature instances identified by the RESOURCEID parameter shall be of the type specified by the TYPENAMES parameter; otherwise the server shall raise an InvalidParameterValue exception (see OGC 06-121r3:2009, Table 25) where the “locator” attribute (see OGC 06-121r3:2009, 8.4) value shall be set to “RESOURCEID”.
The typeNames parameter (see OGC 09-026r2, 6.3.3.1.1) shall be used within an ad hoc query expression to encode the names of one or more correlated feature types to be queried. Individual feature type names shall be encoded as QName (see W3C XML Schema Part 2).
What Nuno is proposing is to accept typenames for single values too (which is what the spec demands as far as I understand).
However, Nuno, it seems to me GeoServer already supports that:
So… confused? Are you talking only about DescribeFeatureType? typenames seems to be indeed ignored there, but the spec only talks
about typenames in the context of ad hoc queries.
On Tue, Jun 6, 2017 at 11:35 AM, Ian Turton <ijturton@anonymised.com> wrote:
see https://osgeo-org.atlassian.net/browse/GEOS-7842 for some other discussion on this
Ian
On 6 June 2017 at 10:15, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Nuno,
I quickly glanced over the specification and I can only find KVP examples using TYPENAMES,
typename is used in the XML.
That said, if GeoServer has bee using TYPENAME until now I’d keep it for backwards compatibility,
so yes, I agree we should be supporting both like the reference implementation
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Ian Turton
On Mon, Jun 5, 2017 at 11:16 PM, Nuno Oliveira <nuno.oliveira@anonymised.comt> wrote:
WFS 2.0 is ambiguous regarding (at least to me) regarding the type name parameter value, in the specification to values used are:
The important specification part is this one:
http://docs.opengeospatial.org/is/09-025r2/09-025r2.html#147
GeoServer is using TYPENAME, OGC CITE tests for WFS 2.0 are using TYPENAMES and WFS 2.0 reference implementation is accepting both:
https://github.com/opengeospatial/cite/wiki/Reference-Implementations
I’m very inclined to also accept both values, i.e. to make GeoServer also accept TYPENAMES.
Any objection ?
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
mob: +39 333 8128928
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
