[Geoserver-devel] WFS argument to FeatureResponse and GeometryResponse
Hi Justin,
as per setting up the correct encoding for all xml output, I had to add a WFS
constructor argument to FeatureResponse and GeometryResponse, and set the
<constructor-arg ref="wfs"/> argument in applicationContext.xml to both
beans.
That is so write(Object value, OutputStream output, Operation operation)
can do
encoder.setEncoding(wfs.getCharSet());
If you have any objection with that speak now before I commit :slight_smile:
regards,
Gabriel
Hi Gabriel,
Sorry, did not see this before. Sounds good to me. Question for you: Did we decide that it would be better to keep on using OWS.getCharSet() (which passes through to GeoServer.getCharSet()), rather then just use the latter directly?
-Justin
Gabriel Roldán wrote:
Hi Justin,
as per setting up the correct encoding for all xml output, I had to add a WFS constructor argument to FeatureResponse and GeometryResponse, and set the <constructor-arg ref="wfs"/> argument in applicationContext.xml to both beans.
can do
regards,
Gabriel
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
Geoserver-devel mailing list
!DSPAM:4007,47ec0a34218941849620573!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
On Friday 28 March 2008 01:20:15 am Justin Deoliveira wrote:
Hi Gabriel,
we did.
[15:59] <jdeolive> groldan: hi
[15:59] <groldan> hi there
[15:59] <groldan> hey, I'm trying to make my head around GEOS-1815 (ensure all
xml output explicity sets charset from GeoServer.getCharSet())
[16:00] <groldan> seems like a hard thing to do, but first
[16:00] <groldan> I wonder if that's really the intent
[16:00] <groldan> I mean
[16:00] <groldan> I seem to remember
[16:00] <jdeolive> groldan: it might be...
[16:00] <jdeolive> one thing
[16:00] <groldan> if a request came with a given encoding, it was desirable
for the response to use the same encoding?
[16:00] <groldan> (not that its happening right now, but still)
[16:00] <jdeolive> when i did wfs 1.1 work... i added WFS.getCharSet() as a
wya to configure wfs =
[16:01] <jdeolive> which was wrong... so in the least that bug should be
replace WFS.getCharSet() with GeoServer.getCharSet()
[16:01] <groldan> you mean OWS.getCharset()
[16:01] <jdeolive> right
[16:02] <groldan> ok, charsets are used all around with a hard to guess
purpose
[16:03] <groldan> for example, there's a SetCharacterEncodingFilter
[16:03] <groldan> then Dispatcher sets the request charset in
preprocessRequest, if it was not set
[16:03] <groldan> and I guess the request charset is only meant to provide a
steady way to parse the request
[16:03] <groldan> but we do not want to use the user provided charset to
encode the result?
[16:04] <jdeolive> groldan: not sure... i think so ?
[16:04] <aaime> you can be almost certain that it's not gs issue
[16:04] <jdeolive> i too am not 100% sure what needs to be done
[16:04] <jdeolive> i think aaime handled the original issue... he might be
able to comment better
[16:05] <groldan> so, we need a deal or I'll be lurking around the whole day
[16:05] <groldan> how about this
[16:05] <groldan> lets make sure all responses use the GeoServer.getCharset()
[16:05] <groldan> to encode xml responses
[16:06] <groldan> then at least we'll have a single entry point where to fix
if the request charset shall be used
[16:06] <jdeolive> groldan: that sounds good, i think that is the most we can
logically do
[16:06] <groldan> (I'm pretty sure using the request charset for the response
came through as a user requirement a time ago, though not sure we ever did
that)
[16:13] <groldan> jdeolive: OWS.getCharset() seems good. As long as we move it
to Service and make it delegate to getGeoServer().getCharset()
[16:13] <groldan> rationale: Service.getCharset() returns the character
encoding for the service xml responses. It comming from the GeoServer
configuration class is an implementation detail irrelevant for the rest of
the service
[16:14] <jdeolive> which Service class?
[16:14] <groldan> Service extends OWS
[16:14] <jdeolive> ahh
[16:14] <jdeolive> yeah that makes sense
[16:14] <aaime> groldan
[16:14] <aaime> that issue was one I opened in response to a user request
[16:14] <jdeolive> although OWS.getCharSet() might just be something we want
to kill completely
[16:15] <jdeolive> so there is no confusion
[16:15] <aaime> that complained german chars are not properly encoded in
geoserver 1.6 anymore
[16:15] <-- oterral123 has left this server.
[16:15] <jdeolive> it is something i did not intend to make it to trunk
[16:15] <aaime> I looked in 1.5.x
[16:15] <groldan> I see it as good practice rather than confusion, if we make
it as I told above
[16:15] <aaime> and there is plenty of places that do use
[16:15] <aaime> we should reinstate all the previous charset settings
[16:15] <groldan> ok, aaime, what were the user request?
[16:15] <aaime> how you do that it's your business
[16:16] <aaime> groldan, please, give me a second to finish :slight_smile:
[16:16] * groldan shuts up
[16:16] <aaime> but you have to make sure every xml encoder
[16:16] <aaime> receives the proper charset
[16:16] <aaime> at the momet we have one case where ows.getCharset is called
[16:16] <aaime> and your fix is as good as any
[16:16] <aaime> but there are other places where the charset was set in 1.5.x
[16:16] <aaime> and it's not anymore today
[16:17] <aaime> so the fix is not only to reroute that ows.gecharset call
[16:17] <aaime> but also to do a similar encoder.setCharset call
[16:17] <aaime> in every other gs services
[16:17] <aaime> that does output xml
[16:17] <aaime> (done)
[16:17] <aaime> looking for that mail
[16:18] <groldan> in a word it is to make sure all xml responses use
GeoServer.getCharset() as the encoding scheme?
[16:18] <aaime> yep
[16:18] <groldan> ok, thanks
[16:18] <aaime> which is mechanical, but not exactly a 5 minutes one :wink:
[16:18] <groldan> mechanical + overhead for a man that does not touches the
services in about 2.5 years
[16:19] <groldan> so that seems good jdeolive/aaime, thanks for the
clarification
[16:19] <jdeolive> groldan: np... sorry that issue is not all that well
defined
[16:19] * jdeolive should spend more time when creating issue reports
[16:20] <aaime> groldan, here is the thread:
http://www.nabble.com/charSet-Settings-will-be-ignored-to16114926.html#a16114926
[16:20] <sigq> Title: Nabble - charSet Settings will be ignored (at
www.nabble.com)
[16:20] <groldan> when I say keep Service.getCharset and make it delegate to
getGeoServer().getCharset() is just to favour the law of Demeter
[16:20] <aaime> don't talk to strangers
[16:20] <aaime> I'm ok with it, np
[16:21] <aaime> groldan, just one thing
[16:21] <groldan> yup
[16:21] <aaime> don't follow that rule on the users ml :wink:
[16:21] <groldan> lol
Gabriel.
-Justin
> Hi Justin,
> both beans.
> can do
> regards,
> Gabriel
>ace _______________________________________________
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
