[Geoserver-devel] wfs cite test failures on master
With the build back we have some cite test failures on WFS.
Last working test on master:
First broken test on master:
Between those two tests we have:
99c8df43e044a4ec30570dabf9272fdc01b4ea24 Merge pull request #2118 from tbarsballe/netcdf-out-fixup e8663e832241f72de186f843aa8f40f92d67bf15 Migrate MultiDimDataStore to ContentDataStore c69fa92b39c563db120a2a0413d868586a7304a0 Merge pull request #2116 from aaime/parallel_catalog_load d4bb0f8caa49c80cab9ed4ee469c5bffdedc4f0e Adding EO metadata templates bdb599e52e0dc214233d6cbd8b50110367dbbc7f [GEOS-7915] Can not display table based pages in Turkish locale 50461e0eee15dd107281aa40265ce7a5c308e68f GSIP-155 follow up: parallelizing catalog loading on the IO side faaa08176c4ada11baf316ba6fa13d61e1e0cd5a Merge pull request #2115 from aaime/gwc_memory_catalog c7fd3a2bab20da83ead80c78103ceebfc2698392 DefaultTileLayerCatalog to mimick the GS own default catalog and keep everything in memory 3d9396a70ffd5a8cd026d2d3c87b81a94dba32b6 Merge pull request #2065 from dvntucker/geos_7937 da457521c5bbf9621e179e7041f260e1801d3870 [GEOS-7937] - Change resource pool to explicitly check URL string fore file-ness fdc360699235a832c1111215b5b4a7a8b353dc86 Remove errant resource file in GeoGig plugin 1aa19b4558c03c3ad3baaa55a755ed80b3e2896b Add missing LZ4 library to GeoGig assembly XML 25881f291526610f4506e34f8b1dedadcd937964 Merge pull request #2076 from thinknirmal/master 9d212d859e23c6ddd486437a06557e2a5676d3f1 Merge pull request #2092 from lavoiej/memory-usage-info c851665551a65c66205cd217cbb4086d069098f4 Merge pull request #2085 from tbarsballe/license 4ef1c02afd3b313e7866c147c7e0aa8c68d02320 Merge pull request #2102 from tbarsballe/GEOS-7900 56d9d09a286df7cf47a9e16c97e6c65b70091f2f Organize imports for geogig plugin 4fd4808aa546da56ed1d7641ea13ea8cc9365ceb Moving metadata payloads out of the main tables 30e785da4de58d7e3134b5b448b1482f11923673 Allow more parallelization during load by using a concurrent structure b1ecec1737ce0f18f5fdac4d6100d8463c382d32 Merge pull request #2106 from aaime/gwc_init_parallel2
fdaea0193866c9a2efd6b7f6bbffb63165661578 Strawman implementation of the opensearch service
Further checking the logs shows a start up failure:
2017-02-20 22:11:09.348:WARN:oejw.WebAppContext:main: Failed startup of context o.e.j.w.WebAppContext@anonymised.com{/geoserver,file:/var/lib/jenkins/workspace/geoserver-cite/geoserver/geoserver-2.11-SNAPSHOT/webapps/geoserver/,STARTING}{/geoserver} org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘wcsURLMapping’ defined in URL [jar:file:/var/lib/jenkins/workspace/geoserver-cite/geoserver/geoserver-2.11-SNAPSHOT/webapps/geoserver/WEB-INF/lib/gs-wcs-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘catalog’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘localWorkspaceCatalog’ defined in URL [jar:file:/var/lib/jenkins/workspace/geoserver-cite/geoserver/geoserver-2.11-SNAPSHOT/webapps/geoserver/WEB-INF/lib/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘advertisedCatalog’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘advertisedCatalog’ defined in URL [jar:file:/var/lib/jenkins/workspace/geoserver-cite/geoserver/geoserver-2.11-SNAPSHOT/webapps/geoserver/WEB-INF/lib/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘secureCatalog’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘accessRulesDao’ defined in URL [jar:file:/var/lib/jenkins/workspace/geoserver-cite/geoserver/geoserver-2.11-SNAPSHOT/webapps/geoserver/WEB-INF/lib/gs-main-2.11-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean ‘rawCatalog’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘rawCatalog’ defined in URL [jar:file:/var/lib/jenkins/workspace/geoserver-cite/geoserver/geoserver-2.11-SNAPSHOT/webapps/geoserver/WEB-INF/lib/gs-main-2.11-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
To repeat: catalog → localWorkspaceCatalog → advertisedCatalog → secureCatalog → accessRulesDao → rawCatalog
Watching this untangle to the end:
Caused by: java.lang.NullPointerException at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:488) at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:387) at org.geoserver.config.DefaultGeoServerLoader.loadCatalog(DefaultGeoServerLoader.java:36) at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:258) at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:59)
The working tests do not have these startup problems :slight_smile:
Jody Garnett
I also see a number of MalformedURLExceptions in the logs of the failing cite tests:
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?service=WFS&version=1.0.0&request=GetCapabilities; SystemID: file:/var/lib/jenkins/workspace/geoserver-cite/tools/target/work/~2Fvar~2Flib~2Fjenkins~2Fworkspace~2Fgeoserver-cite~2Ftools~2Fengine~2Fscripts~2Fwfs-1.0.0~2Fctl~2Fwfs.xml/wfs$test1.0.0-basic-getcapabilities-get-1.test; Line#: 45; Column#: -1
     [exec] Feb 20, 2017 11:24:46 PM com.occamlab.te.TECore executeTest
     [exec] SEVERE: SaxonApiException
On the subject of the cite tests, I cannot seem to find the run.sh script responsible for initiating these tests in version control anywhere. Unless someone can point me to its location, I would like to add it. (geoserver/geoserver seems like the most appropriate repo, perhaps in the build directory?)
Torben
On Mon, Feb 20, 2017 at 3:14 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Hey
Had a quick,keep looking, it’s my fault, fails during catalog loading. The cite data dirs are ancient, probably miss the default ws configuration.
Will fix ASAP.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function [java.net](http://java.net).MalformedURLException: no protocol: ?service=WFS&version=1.0.0&request=GetCapabilities; SystemID: file:/var/lib/jenkins/workspace/geoserver-cite/tools/target/work/~2Fvar~2Flib~2Fjenkins~2Fworkspace~2Fgeoserver-cite~2Ftools~2Fengine~2Fscripts~2Fwfs-1.0.0~2Fctl~2Fwfs.xml/wfs$test1.0.0-basic-getcapabilities-get-1.test; Line#: 45; Column#: -1
Torben
Jody Garnett
Geoserver-devel@anonymised.comrge.net
Fixed
On Tue, Feb 21, 2017 at 7:19 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hey
Will fix ASAP.
Torben
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
What was actually missing - in case upgrades in the wild run into the problem?
Like was cite so old it was missing the “default” setting?
Hey
Will fix ASAP.
Torben
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Feb 21, 2017 at 6:00 PM, Jody Garnett <jody.garnett@anonymised.com>
problem?
The default.xml indicator:
https://github.com/geoserver/geoserver/blob/master/data/release/workspaces/default.xml
But I did not add it in the CITE tests, changed the code so that it works
also without like the old code did.
So there should not be a need for upgrade instructions
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Andrea, cite tests have passed and I am kicking off the release process with the following revisions:
version = 2.11-SNAPSHOT
git revision = ff37acf9c5512ee99ea3e6efa0fb16bd5c747371
git branch = origin/master
build date = 21-Feb-2017 10:41
geotools version = 17-SNAPSHOT
geotools revision = 1dd53ef2f2234a98752283f405149f3e7bfc4d3b
geowebcache version = 1.11-SNAPSHOT
geowebcache revision = f21c277474fcde708d2102e6efea6ea94633e7a4/f21c2
I am trying to think what we would like to highlight in this release announcement:
  • faster startup (obviously)
  • new extensions
  • “Opaque container” (we can link to docs)
  • layer group security, we can provide an example
Anything else we should be on the look out for?
On 21 February 2017 at 09:04, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Tue, Feb 21, 2017 at 6:00 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
But I did not add it in the CITE tests, changed the code so that it works also without like the old code did.
Ing. Andrea Aime
@geowolf
Technical Lead
