[Geoserver-devel] WFS Deadlock on GeoServer 1.5.x only effects shapefiles
For clairification; this bug only effects shapefile layers (indexed or otherwise) so the TOPP intergration showcase using GeoServer 1.5.3 and PostGIS should be good to go.
Jody
A team of mad uDig testers (tm) has tried every release back to GeoServer 1.4.0.
- GeoServer 1.4.1 was the last release not to deadlock.
Producing this dealock was found at this time for two reasons:
- Jesse has been getting better about refreshing the screen
- Graham has a fancy new box w/ two processors
- and of course it was our first solid QA run for a while.
Jody
Hi list,
Have you gotten any reports of Geoserver 1.5.3 getting locked on a dataset after a few edits take place? Here's what I'm doing:
1. Add a geoserver layer (say tasmania roads).
2. Edit it a bunch of times (with uDig, any version as far as I can tell)
Eventually it will lock up (not uDig but rendering that layer). I can close the map and try to the the layer with a WMS. That will also never return (until uDig times out). All other layers are fine.
I kill GeoServer and it looks like it is deadlocking on the Shapefile Lock... Sounds like my fault :frowning: or possibly a result of one of Andreas changes and I missed the mistake as well.
I think one of two things are happening:
1. The lock has an internal race condition and should be replaced with a Java 5 Read/Write lock
2. Some object is aquiring the lock (read or write I don't know right now) and forgetting to release it (or throwing an exception so that it doesn't get released).
Jesse.
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geotools-devel mailing list
Geotools-devel@lists.sourceforge.net
geotools-devel List Signup and Options
